It is currently Tue Jul 29, 2025 11:31 pm
PostPosted: Tue Mar 22, 2016 8:37 pm
I have a mk 2 cooper s block that is currently on +60 thou but looks like it may need to be bored. So my question is can I bore it out again and still be able to reline after that if necessary? If I can what is the max piston size I can go to?
I see GR sells a 72.5mm (+74thou) and there is a 73mm (+94thou)
Rod
PostPosted: Tue Mar 22, 2016 8:47 pm
You can go 72.5, 73.0, 73.5. I'm pretty sure GR has sleeved S blocks back from 73.5, ring him and check.
PostPosted: Tue Mar 22, 2016 9:26 pm
has the block been offset bored to get it to .060" ?
PostPosted: Tue Mar 22, 2016 9:52 pm
Not that I'm aware of.
Rod
Users browsing this forum: Barkfast, Bing [Bot] and 106 guests
