It is currently Wed Jul 30, 2025 8:22 am
 Post subject: Re: Mounting 10" tyres
PostPosted: Fri Mar 11, 2016 2:46 pm
Thread revival - so I'll just get the local tyre shop to machine mount these tyres to the rims but tell them to do it over the inner rim side first. Sound like a good plan?
PostPosted: Fri Mar 11, 2016 6:41 pm
yes, the big problem is the "Usual" side to fit a tyre is not the side to fit on a mini rim
what most people havn`t mentioned is that the tyre need to have the bead set-into the wheel-well properly to be able to fit the tyre without damaging it
"This" is the issue,,, !!!
if you look at a wheel/tyre combo & how it fits, you need to get the bead to sit within the wheel-well on one side before tyring to accomplish full fitment of that side`s whole bead
when "Normal" people try to fit a tyre they are shown how to do it but not told "Why"
so that "Normal" person doesn`t understand the simple physics involved
if they`re shown the "Right" way to fit "ANY" tyre & told the "Reason" why it`s meant to be fitted that way
then funny enough there`s no problem
opposite side into the wheel well & it almost falls on
people need to look & see that the easiest way is the short side first :-)
Ya cannot change the laws of physics, """bead""" me up Scotty :-)
try 30 year old speedway tyres by hand & then tell me what you reckon :-)
PostPosted: Sat Mar 12, 2016 7:51 pm
Practice on a go kart rim and see which way is easiest :wink: .
PostPosted: Sun Mar 13, 2016 7:14 pm
If you go to your tyre shop and tell them the rims are reverse mount they will know what you mean.
