It is currently Wed Jul 30, 2025 9:16 am
PostPosted: Sun Jan 03, 2016 9:42 am
Hi all,
Well my old su fuel pump has finally died. A new one is quite expensive. What are peoples opinions or experience with the facet pumps, such as the one I found on EBay? Cheers, Richard.
http://pages.ebay.com/link/?nav=item.vi ... 18&alt=web
PostPosted: Sun Jan 03, 2016 10:35 am
Excellent. Am using them on several cars and never had any problems.
Curly
PostPosted: Sun Jan 03, 2016 11:18 am
Rover Cooper
what if I have a SPI, what should I use.:'(
@ bwcs1968,
I used them on both our cars, no problems. Cheap, and reliable.
I mount them on a Mini centre exhaust mount (the big square rubber one) Bolts line up, just drill 1 hole 8.5mm in the vertical web and stick a 5/16 UNF Nyloc nut on it.
PostPosted: Sun Jan 03, 2016 2:29 pm
Has anyone tried the points less system?
PostPosted: Sun Jan 03, 2016 5:12 pm
On the SU pumps? They go well too.
PostPosted: Sun Jan 03, 2016 6:06 pm
Please explain?
PostPosted: Sun Jan 03, 2016 6:29 pm
they make ones with out points, or you can buy kit to modify yours.
http://sucarb.co.uk/electronic-pump-con ... -12-v.html
PostPosted: Sun Jan 03, 2016 6:40 pm
I think I'll go with the facet pump, I pulled my su apart and cleaned the points, put it all back in and it ran for 10 seconds and stopped again. Brrr.
PostPosted: Sun Jan 03, 2016 8:22 pm
The SUs can reportedly only handle 2.5 psi (a reliable source told me that with regards to my HIF44).
Do the Facets (4-6 psi) drop pressure by the time they hit the front of the car, do people run regulators, or do the SUs just deal with it?
Also - I'm assuming no one uses a return line with SUs?
[I'm about to buy a Facet pump for the rear, with a fuel regulator in the engine bay to drop it to 2psi just before the carby. But open to recommendations]
PostPosted: Sun Jan 03, 2016 8:36 pm
Facet pumps come with a range of different delivery pressures. Try to get the right one.
PostPosted: Sun Jan 03, 2016 8:38 pm
Ah okay - so is there a pressure drop across the length of the fuel line I should worry about or if I need max 2.5 psi at the carby, should I just get a 2.5 psi pump?
PostPosted: Sun Jan 03, 2016 9:31 pm
I think my square Facet pump is 3-4psi. It works fine with the Dellorto, and with the HS6 SU I had on before.
I don't use a regulator, as cheap ones do more harm than good. Something else to fail.
PostPosted: Sun Jan 03, 2016 10:07 pm
Thanks for putting up with the thread hijack. FYI for future readers: with this advice added to previous research I ended up ordering the following Holley pump - not running a regulator.
Holley website wrote:
25 GPH HOLLEY MIGHTY MITE ELECTRIC FUEL PUMP
Street Carbureted Applications Compatible with all fuels and fuel additives
PART# 12-426
FEATURESOVERVIEWSPECS
12 volt operation
1.5-4 psi operating pressure
25 gal/hr flow
Good for up to 300HP naturally aspirated
Reliable solid state design provides longer life
Compatible with all fuels and fuel additives (gas, diesel, blended alcohol, e-85)
Simple 2 wire hookup
Self-priming and regulating
12” dry lift capable
Quiet operation – 65db
Great for carbureted trucks, cars, generators and agricultural equipment – also makes a great transfer pump
Engineered and matched performance with Holley®, Demon®, Quick Fuel® and Edelbrock® carburetors(all trademarks are property of their respective owners. Edelbrock is a registered trademark of Edelbrock,LLC)
Comes with fuel filter, fittings and mounting hardware
Made in the USA
TECH RESOURCESPARTS & KITS
Should be mounted with in 12" of the fuel tank.
http://documents.holley.com/199r10683rev2.pdf
PostPosted: Sun Jan 03, 2016 10:48 pm
Has anyone has experience with these carter pumps?
I'm wary of facet pumps, heard a lot of bad things about them.
Users browsing this forum: Bing [Bot] and 82 guests
