It is currently Sat Aug 02, 2025 8:27 am
 Post subject: Clutch slave cylinders
PostPosted: Fri Dec 25, 2015 1:59 pm
Decided to put a kit in my mate's Clubby clutch slave cylinder to go with his `new' motor.
Took it apart, gave it a quick hone and then found the new 7/8" seal in the kit wouldn't fit.
????? :shock:
Somebody has sleeved it with S/S. Would be nice if they'd bored the casting out bigger first, then bored the sleeve to 7/8" and used stock seals and piston!
Now I need to go find a 13/16" cup seal instead. :evil:
PostPosted: Fri Dec 25, 2015 2:24 pm
Working over x-mas? I am staying away from the shed today. Its 39 degrees outside.
PostPosted: Sat Dec 26, 2015 6:01 pm
Mine is undersized ..to allow for the other non standard bits. A smaller bore gives a bigger throw.
At the time it was made I was told that older Toranas used the same (or at least similar but with reduced bore) cylinder.
Cheers, Ian
PostPosted: Sat Dec 26, 2015 6:12 pm
That may be what it's off, as the piston, & seal spreader are `undersized' too.
I'm sure it'll work fine, once I get a 13/16" cup seal [on Tuesday?] here's hoping B&R Brakes are open this week..
PostPosted: Sun Dec 27, 2015 7:07 am
Would the sleeve take a careful 1/16 removal? :twisted:
PostPosted: Sun Dec 27, 2015 7:11 am
Good luck setting it up to run true first. And the piston it has won't fit If I bore it out.
Nah I'll just get a 13/16" cup.
It's only running a stock Cooper S blue dot diaphragm. Motor is a `short stroke 1108' (68mm bore, 998 crank)
PostPosted: Sun Dec 27, 2015 7:23 am
Good luck setting it up to run true first...hardly a challenge for an old Eveleigh boy :!: :lol: :lol:
And the piston it has won't fit If I bore it out...get another :!:
Nah I'll just get a 13/16" cup....sounds like a plan :!:
It's only running a stock Cooper S blue dot diaphragm...only :?:
Motor is a `short stroke 1108' (68mm bore, 998 crank)...nice :D
PostPosted: Thu Dec 31, 2015 4:09 pm
Just buy a new slave cyl, there cheap!!
PostPosted: Thu Dec 31, 2015 4:12 pm
But they're not original!
PostPosted: Thu Dec 31, 2015 4:35 pm
Sorry, I'm not a pureist lofnl
PostPosted: Thu Dec 31, 2015 4:53 pm
And the cheap ones are all missing an essential part (seal spreader).
All fixed, I put a new 13/16" cup seal in it. :P
PostPosted: Thu Dec 31, 2015 5:00 pm
You mean, a backup ring?
PostPosted: Thu Dec 31, 2015 5:19 pm
Seal spreader, it keeps the seal in contact with the bore.
Without it, they suck air once the seal starts to wear.
Can't buy them as a spare part now but DrMini has made a few up from HDPE.
Spring sits inside it. Originals had 3 holes but it's easier to space 4 on my mill.
PostPosted: Thu Dec 31, 2015 6:21 pm
This can make you one.
PostPosted: Thu Dec 31, 2015 6:23 pm
DavidE wrote:
[quote="bluewhitecoopers1968"]Just buy a new slave cyl, there cheap!!
This can make you one.[/quote]
Possibly not.... :)
Users browsing this forum: No registered users and 112 guests
