It is currently Thu Jul 17, 2025 10:48 am
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 524, 525, 526, 527, 528, 529, 530 ... 568  Next
PostPosted: Tue Nov 17, 2015 1:40 pm
I had the day off, and had an awesome run up and down Macquarie Pass :D
PostPosted: Wed Nov 18, 2015 8:05 am
Finally got back onto the 1293 build last night...for ROO the Aussie Window Van.
Renovated 2 levels of the house this year, had cousin & hubby from Brissy over for holiday, had family holiday with son, wife & grand daughters, was responsible for our big 74th community celebration...3 weeks before Mini Meet West (western Canada & USA) which I had been helping with since last year.
No more excuses...
Yesterday we took status: both blocks crack tested, cleaned, mains align honed, crank/main journal clearance addressed (mine solved by polishing the main journals on the new A+ crank), decks milled as needed (mine the least amount possible, the other need material removed to bring new Rover std pistons up the bores), my head rebuilt with hardened exhaust seats with new guides/new valves/springs...so
Last night opened up/smoother flow for oil into filter and into/out of pump. After thorough wash, rodding etc. and dry, oil gallery plugs/freeze plugs installed, then cam bearings in both blocks.
Tonight will install crank, rods, pistons, cams and check cc of piston dishes and combustion chambers...mine very close to 10:1 now. My block had been built years ago as a race engine (but never actually ran) so 20 over Cooper S 19320 pistons (oil drain back via holes not slots) were only 13 thou down the bore. Head likely to get the least amount of material removed to clean up.
The other 1275 block was a Rover SPI unit that went to Japan and new std. Rover pistons were more than 20 thou down the bore.
PostPosted: Sun Nov 22, 2015 2:08 pm
This needs to be a sticky page always at the top mick
Went to rodstock car show and seen a green fj ute with clubman Leyland back lights
There was a dark purple clubby there as well
And not forgetting the stupid retard joke that goes to all the car shows taking pics at the gate he didn't get my mini again it was at home I went for the swap meet
PostPosted: Sun Nov 22, 2015 4:14 pm
I've finally sorted out the horn button on my new steering wheel, now I can honk again!
PostPosted: Mon Nov 23, 2015 7:25 am
This morning was like the good the bad and the ugly.
The Good - mini started first time as always, started it up and drove it 4km down the road to the trimming shop to have the seats trimmed, should get it back within a couple of weeks so will be all new for xmas.
The bad - It was a little early for the misses to get all the kids in the car and follow me so decided to run the 4km home
The Ugly - My heaving sweating form when I got back home !!
1972 Leyland Mini Clubman
2000 Honda CBR929RR
PostPosted: Mon Nov 23, 2015 2:47 pm
Fitted my passenger side Vilosport handle
....you just lost him his insurance bonus!
997
PostPosted: Mon Nov 23, 2015 4:26 pm
Yesterday I decided to cut the rust out of the boot floor - spare wheel area - and fabricate a new piece. I might weld it in today.
I didn't want to buy a new floor as I had spare metal laying about and it didn't warrant it.
I shaped the metal to keep the wheel inset. The radius I used was 195mm. The circle still looks like a circle. [SMILING FACE WITH SMILING EYES]
1966 Morris Mini Minor Saloon (Dot) - 1275 Auto - Mongrel
1968 Morris Mini Van (Ivan) - 998 Auto - Mongrel
1968 Morris Mini.Matic (George) - Original
1968 Morris Mini.Matic (Charlie) - Original
PostPosted: Mon Nov 23, 2015 7:32 pm
Can't wait to see the finished product
PostPosted: Mon Nov 23, 2015 8:29 pm
Finally finished my rotisserie. Turns around nicely.
PostPosted: Fri Nov 27, 2015 8:58 pm
https://www.youtube.com/watch?v=PGNiXGX2nLU - please refer to 1:00
Also Re-Adjusted the minivation bonnet hinges, the back was being pushed up a little, realised I was not all the way down in the slots, will see how we go.
Nick
PostPosted: Fri Nov 27, 2015 9:32 pm
Put a boot over the freshly packed cv
Re installed shaft
Replaced tie rod end boot
Put it all back together.
Swapped wheels from other rolling shell onto the new mini. Realised the rears don't fit without spacer drums.
Clay bar, Polish, wax roof to see how it turned out.
Productive day :)
I have a problem.. apparently
PostPosted: Wed Dec 09, 2015 4:00 pm
Picked the car up from the trim shop and the new seats look quality. Car is a bit dusty so will give a shine up at the weekend and take some pics. Now looking forward to a summer of driving and enjoying the car.
2000 Honda CBR929RR
PostPosted: Mon Dec 14, 2015 10:23 am
Mini was assigned Santa delivery duty on Saturday.
Nick
PostPosted: Mon Dec 14, 2015 7:52 pm
Got the new Know carpet installed the other week, only yesterday did the interior all get put back in. Absolutely loving the results. The red carpet goes so nicely!
PostPosted: Mon Dec 14, 2015 7:55 pm
What's know carpet... where did you get it from. It looks good!
