It is currently Fri Jul 18, 2025 5:06 am
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 514, 515, 516, 517, 518, 519, 520 ... 568  Next
PostPosted: Tue Jun 30, 2015 6:44 pm
Helped Laingy drop the now 1387 stroker back into his van.
PostPosted: Tue Jun 30, 2015 7:58 pm
Has that got my old gearbox under it?
PostPosted: Tue Jun 30, 2015 8:52 pm
Well yeah KB, it has your S gear set, but in a remote box not your rod change one.
After 2650km, due to a top ring failure we had to change the pistons and bore it again. So, it's got 1387cc now, not 1377. I'll let Laingy tell the sad story.
PostPosted: Tue Jun 30, 2015 10:55 pm
Changed the front passenger wheel bearing and put a new centre exhaust bracket on my moke. .
PostPosted: Mon Jul 06, 2015 2:09 pm
Put 175 main jets into the 45 Dellorto instead of the 170s. It's less cranky when dead cold now. :)
PostPosted: Mon Jul 06, 2015 5:00 pm
I looked at mine on night shift at the moment keeping the streets safe. Can't wait to start to use it once I get it pitted and registered next week.
PostPosted: Tue Jul 07, 2015 10:26 pm
On night shift until Thursday. Can't walk past the garage without sneezing a peek at her. Only had it five days can't wait to start using it and getting it ready for the tassie mini fest in November.
PostPosted: Sat Jul 11, 2015 3:59 pm
Stripped dash cluster today, cleaned the glass and plastics, reassembled with a new printed circuit.
Plastidipped grill black. if i still like it black in a few months ill paint it properly
Might fiddle with suspension later
PostPosted: Sat Jul 11, 2015 5:39 pm
Assembling a SCCR gearbox for a friend and was at the stage of fitting the (Quaiffe) diff in place. Set it all up with shims, screwed down the side covers - all good :D . Then went to torque the bolts up and 3 were soft, so off with the side covers and out with the helicoil kit :twisted:
The output shafts are similar to the pot joint set up with wire spring clips that hold the Hardy-Spicer drive flanges in place. One of these snapped when sliding the flange on and of course the broken bits ended up inside the side cover, which then had to removed to recover the bits. Made a new spring clip from an old door spring, refitted side cover and drive flange. Ended up covered in sticky gasket goo mixed with blood from where the spring bit my finger :evil:
Another simple job that took all afternoon to accomplish - the weather was shocking so at least I ended up doing something useful :roll:
Curly
PostPosted: Sat Jul 11, 2015 5:57 pm
The grill looks great in black! Tough as
PostPosted: Sat Jul 11, 2015 7:04 pm
This is one of those repairs where the outcome is sooooo much better than the original thread.
PostPosted: Sun Jul 12, 2015 1:15 am
Flushed out my crankcase and gearbox with half a tank of petrol... then started removing the mechanical fuel pump so that I can put a kit through it :-(
Don't listen to what I am saying... just understand what I mean.
PostPosted: Sun Jul 12, 2015 7:43 am
Spent the whole of yesterday assembling a 1100 +040 short motor following Graham Russell's small bore project notes to the letter, still not finished.
Mini's I grew up with
Slot car couch
PostPosted: Sun Jul 12, 2015 7:48 am
Oh Daaaaaaaddddd :P
PostPosted: Sun Jul 12, 2015 12:02 pm
My job for Friday and yesterday...figure out what was causing that gearbox whine
