It is currently Mon Jul 14, 2025 12:33 am
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 511, 512, 513, 514, 515, 516, 517 ... 568  Next
PostPosted: Fri May 01, 2015 2:39 pm
Presents from JS via the postie
Nick
PostPosted: Sat May 02, 2015 4:01 pm
Ordered two new seats for the mini
1963 850 - laid up
PostPosted: Sat May 02, 2015 4:12 pm
Rebuilt a gearbox for the van. Upgraded to a 4 syncro remote.
Just need my order of other bits from Minikingdom to arrive and can complete the diff.:)
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Tue May 05, 2015 4:47 pm
I finally found the last piece for my jigsaw. An AWA 25M carphone two-way as originally fitted to the NSW Police Mk2 "S' STP cars back in the day. This will go very nicely in my ex-NSW Police Mk2 'S' ... along with all the other genuine NSW Police period accoutrements I have been collecting over the past twelve months.
Woot!
Davo
1965 Mk1 Cooper S Sprint/Hillclimb/Rally Car
2012 Land Rover Defender 90
PostPosted: Tue May 05, 2015 6:53 pm
WOW!!
I was blown away by what it went for.....
I was going to buy it and was prepared to pay $200....
Stacks more than what I expected
But if it was the last thing needed, I can understand I suppose
Congratulations on finding that elusive last piece.
PostPosted: Thu May 07, 2015 6:29 pm
got my flywheel off!!!!! yay!!!!
only took an 8 tonne hydraulic puller
PostPosted: Thu May 07, 2015 6:57 pm
Made up a bronze threaded adaptor to replace the bit that broke off the back of my near new 200KMH S speedo where the cable screws on.
No wonder that it broke, it's an M12x1.0 thread with an 8.5mm OD bronze bush inside it. Bottom of this thread diameter is about 11.0mm, so there was only 2.5mm/2 = 1.25mm of metal (cast alloy) thickness. Too bloody weak....!
PostPosted: Fri May 08, 2015 6:42 pm
Removing the scores of small dings in the front floor pans. The front ender the car had obviously bent up the front floor pans which were just hammered flat. I've got to remove the dozens of small hammer marks as best I can.
Also removing buckets of garnet still coming out of every orrifice in the car :roll:
PostPosted: Fri May 08, 2015 8:03 pm
Nothing to see here. :oops:
PostPosted: Sat May 09, 2015 8:47 pm
Had a go at lightening a flywheel for my small bore project.
5/72 Clubman Gt
PostPosted: Sat May 09, 2015 8:49 pm
Front panels ordered :cool:
PostPosted: Sat May 09, 2015 8:51 pm
Stripped down both rear brake assemblies and they've been soaking in degreaser all day. Next time I'll be properly cleaning them, respraying, repairing and replacing the components and putting them back together. Got the final patches welded on, ground it all back. Also got half the bogging done. Will be sanding that down and primer all over next time.
Why Drink And Drive When You Can Smoke Dope And Fly!?
PostPosted: Sat May 09, 2015 8:52 pm
Found another piece for my new race engine. Slowly getting there.
PostPosted: Sun May 10, 2015 2:37 pm
Ordered a new tacho (Auto Gage, 8000rpm) for the Mini. My 1971 vintage ex-Fiat 124BC one is now jumping around like an old Clubby one, the needle damping has finally gone awol.
PostPosted: Sun May 10, 2015 4:16 pm
Give my baby some new shoes
