It is currently Fri Jun 27, 2025 3:40 am
Post new topic Reply to topic  [ 538 posts ]  Go to page Previous  1 ... 18, 19, 20, 21, 22, 23, 24 ... 36  Next
PostPosted: Thu Jan 01, 2015 7:03 am
LeylandMiniPhil98 wrote:
Do you have a hobby store you can go to, or perhaps call?
Well I used to go to wings and things but that's closed up, l used the go to hobby in the hills but that's now closed as well, l mate at work who races nitro off road recommended Keller hobbies at Liverpool, might go out for a look.
1993 R32 Nissan Skyline GTR
PostPosted: Thu Jan 01, 2015 12:03 pm
davem wrote:
ryan wrote:
I would recommend getting what is run in the mini class, which is the hobbywing 13t/3000kv brushless combo with the 35A Esc. Like this http://m.ebay.com.au/itm/271100020947?nav=SEARCH
For a lips battery, most guys at my track including myself use this http://www.hobbyking.com/hobbyking/stor ... _Pack.html
Grab a lion charger like this and you are set (you need the one with the Aussie plug. http://www.hobbyking.com/hobbyking/stor ... _plug.html
You could get this set up with 2 batteries for around $200 landed. That would give you 20-30mins per battery and you can charge the spare while using the other.
Cheers, I've already got a similar charger so that helps,do you guys use fire bags when charging, how much of a performance difference is the motor upgrade.
It's an epic combo. Cheap. Reliable. Simple. FAST. In a Mini you're limited by its internal gearing and max pinion size of 20T, but I have seen these combo's pushed hard in a Touring Car geared right down and they are almost as quick as a Mod car.
I use bags when I charge (except in my F1 at the track as it's a bit tricky to get the battery out as it's taped in and held in with the shock mount). I always use the bags at home, and at the track for my Mini and Touring Car.
PostPosted: Sat Feb 07, 2015 6:38 pm
looks like I've started something... my local club are having a "mini revival" - everyone is getting their old minis out to go racing again :D
PostPosted: Sun Feb 08, 2015 12:28 pm
Let's hope it starts a flow on around all the other clubs in Victoria!
PostPosted: Sun Feb 08, 2015 4:54 pm
and NSW!
Ryan Filippi
Minis In The Gong
[email protected]
www.minisinthegong.com.au
PostPosted: Tue Feb 10, 2015 8:10 pm
I'm currently trying to research vaccuforming around Brisbane to see if someone can do me a one off 1/5 body for my baja. I'm trying to create rally bodies so hopefully, I will be able to start something there too...perhaps even the World Remote Control Rallying Championship...my baja is RWD, so my main focus is a mk2 escort for that. Then if I can get my hands on one of the club members losi 5IVE-Ts, the 4wd equivalent, I'm going to try and make some modern WRC car too. Perhaps even a 90s escort, fiesta, focus, impreza, something like that. I want. To create a mini shell too but I don't know what I'd put that on. If I wanted accuracy, I'd have to build a custom chassis so it was front wheel drive.
Why Drink And Drive When You Can Smoke Dope And Fly!?
PostPosted: Tue Feb 10, 2015 8:12 pm
Vaccuforming is easy enough, there are tons of people who can do it. It's just getting the mould right. The dimensions, making it fit onto RC chassis' and whatnot. Quite tedious unfortunately...
PostPosted: Sun Feb 15, 2015 4:11 pm
there were 8 there last night I think. I couldn't stay for long...
mine was the only one that had wheel hop on corners, what makes them do that?
I have some new bits coming from Japan which includes a set of rear uprights, I discovered a while ago that one of mine (plastic) has about 4 degrees of toe in, but the other has the proper amount
PostPosted: Thu Feb 19, 2015 3:34 pm
anyone? :)
PostPosted: Thu Feb 19, 2015 8:27 pm
No idea sorry. Not a problem I have to deal with.
PostPosted: Wed Feb 25, 2015 8:23 pm
Hey simon,
What shock oil are you using? I was running 45wt and getting lots of wheel hop. I changed to 27.5wt and now it's much better.
What about springs? I have blue front and red back.
Ryan Filippi
Minis In The Gong
[email protected]
PostPosted: Thu Feb 26, 2015 10:38 am
ahh - I'd guessed that suspension was too hard - bloody WT ratings though, they're all different from brand to brand! http://www.rcrcr.com/index.php?option=c ... &Itemid=46
I'm using 500 cts now, I have some 350 I'll put in
and I'm using yellow/blue springs
so everything is stiffer than what you're using
PostPosted: Thu Feb 26, 2015 8:04 pm
I put the rears with the blue springs and 500cts on the front, and redid the fronts with the 350cts and red springs and took it to the track. Was a bit better, so then changed the oil in the fronts to the 350 and it was a bit better again, but now understeers more than it did...
So I need the back-end softer still?
PostPosted: Thu Feb 26, 2015 9:03 pm
My oil is 313cst. So you're close.
What tyres/wheels are you using?
Are you running a front shock tower? If so, what holes?
Ryan Filippi
Minis In The Gong
[email protected]
PostPosted: Thu Feb 26, 2015 9:44 pm
ride 3035 front
shimizu rear sp
yes shock tower, outer holes
