It is currently Tue Jul 15, 2025 1:10 am
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 503, 504, 505, 506, 507, 508, 509 ... 568  Next
PostPosted: Tue Jan 27, 2015 8:16 pm
have had worst luck (or im just a idiot) changing the cones/trumpets. i have a black finger nail from hitting it and a pi$sd off look on my face...
PostPosted: Tue Jan 27, 2015 8:51 pm
Could be worse. My boss always seems to find a way of hitting himself in the nuts :o
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Tue Jan 27, 2015 9:23 pm
kiwiinwgtn wrote:
Fitted the headers and mini spares inlet manifold. What a pita to fit surley it would have only taken a few minutes to modify the moulds so you can get a small socket on the 3rd stud from the left. I adjusted it with a die grinder.
Socket is tight and just comes off. I will buy a cheap one and turn it down in the lathe to make it fit nicely.
Is that all? I had one where the studs were 3mm> with respect to the ports. We had to TIG weld one end of the flanges to build them up, then mill all the flange ends and slots again.
WHY cannot people machine new things properly.... :evil:
Agree a simple trial fit is not that hard
PostPosted: Tue Jan 27, 2015 9:43 pm
Mick wrote:
This should be filed under "What did you do TO your Mini today" but..
I dropped a grease gun while restructuring the workshop, and put a 1 inch scratch down the front guard
Click the link to find a family friendly version my reaction.
http://nooooooooooooooo.com/
Im sure the auto paint scratch remover pen will be on one of them tv shopping channels soon
You can tell us if they work or not
PostPosted: Wed Jan 28, 2015 10:34 am
I reclaimed some AYA6001 cast iron rack dampers. Now NLA new.
They wear over time; when they are too short to not reach above the rack body and allow shimming, I cook the oil out with the oxy torch, then braze the end up where the wave washers sit (with nickel bronze rod) and re-machine them ~1mm longer.
[edit] A pic-
Last edited by drmini in aust on Mon Feb 02, 2015 9:37 pm, edited 1 time in total.
PostPosted: Sun Feb 01, 2015 8:02 pm
I got door glass in both sides of the 850. Also got passenger door trims and chrome. Passenger door mirror too.
Inside firewall and wheel arch felt glued in.
Brake light switch fitted to pedal box.
Boot lid on. That seal I had painstakingly installed was too stiff so out it came and all 22 ferking clips and on went a seal on the body instead.
Steering column in just so I could push it around. Not final until carpets sorted.
Started measuring out holes for clips for grille whiskers.
M
PostPosted: Sun Feb 01, 2015 8:34 pm
I stared at the rust and have picked an easy-ish place to start .... wish me luck { 78 ls with speed holes }
PostPosted: Sun Feb 01, 2015 8:49 pm
Good luck :)
5/72 Clubman Gt
PostPosted: Mon Feb 02, 2015 7:26 pm
Removed head studs, and other ancillary bits off the block in preparation for the engine strip down.
PostPosted: Tue Feb 03, 2015 7:15 am
Not on the mini exactly but related to what I will do to it next. Started reading Tuning BL's A series engine by David Vizard, thought it would be good to understand some basics before I decide what engine to build.
1972 Leyland Mini Clubman
2000 Honda CBR929RR
PostPosted: Tue Feb 03, 2015 2:14 pm
Took me 6 months but I finally finished turning my 8x5 cage trailer into a mini car trailer. Takes about 10 minutes to change it back.
PostPosted: Tue Feb 03, 2015 9:09 pm
Fitted my new PCB to my gauges, really easy to do and it all works....quality
2000 Honda CBR929RR
PostPosted: Tue Feb 03, 2015 10:33 pm
Not on the mini, but on Saturday I staged a race between minisport UK and minisport AUS.
Aus is the winner with my new hi-lo's and trumpets arriving today..
Still waiting on the cones, and some other bits and pieces.
You can't drive your shares on the weekend...
PostPosted: Tue Feb 03, 2015 10:35 pm
Still rearranging the garage, many forgotten mini bits and pieces being found.
Its like an adventure really...
PostPosted: Sat Feb 07, 2015 11:29 pm
Got the brake light pressure switch working again (tapped gently with a hammer, cleaned terminals).
