It is currently Wed Jun 25, 2025 5:45 am
PostPosted: Sun Jan 25, 2015 7:05 pm
How much for? Could you do mine? :x
PostPosted: Tue Jan 27, 2015 7:29 am
Theres a rover 1275 A+ motor for sale on here. Has dry subframe while mine has wet.
Would that motor work on mine? the later models had longer ratio boxes did they not? thank
PostPosted: Tue Jan 27, 2015 11:34 am
You will just need a stock MiniMatic subframe for it. Auto box is too bulky to fit in a normal one. The auto subby is wider and longer.
There should be some about, I sold one last year for $100 bare.
PostPosted: Tue Jan 27, 2015 12:46 pm
I reckon my subframe should work then.
Did the rovers have a longer gear ratio?
3,500 he wants for motor and box. Which is alright by me really. If I can use my wet subframe then that would be great too
PostPosted: Tue Jan 27, 2015 3:25 pm
It should bolt in fine.
Can't help with the gear ratios for Rover ones, but the MiniMatic 998 and Morris 1100S/1300 automatics sold here had the same overall 3.76:1 ratio.
PostPosted: Tue Jan 27, 2015 3:51 pm
According to this site the A+ could come with a "2.760" diff (69/25), which should be a bit nicer on the highway?
With the auto 1.15:1 drop gear that'd be about 3.17:1 overall diff ratio
https://www.somerfordmini.co.uk/eshop/i ... age&id=156
PostPosted: Tue Jan 27, 2015 6:17 pm
What was this price for , a rebuilt 1275 auto , or , a rebuildable 1275 auto ?
Only reason i ask is that i have a complete rebuildable 1275 Auto .
PostPosted: Tue Jan 27, 2015 8:53 pm
Just one that came out of a rover. goodie can you please pm me how much you're after? Thanjs
PostPosted: Wed Jan 28, 2015 7:21 am
Be aware some parts for the early ones are unobtainium in UK now. Not sure about the Rovers.
If looking for someone to rebuild, Mini Classic in Ermington (Sydney) does them.
PostPosted: Wed Jan 28, 2015 7:49 am
Thank you. thats what I heard.
Rover parts not too hard I reckon.We had a big local shop back home overseas that stocked them. and seeing as most of the japanese rovers end up there I dont imagine it would be too hard.
I think I might go the rover 1275. have mates telling me to stay with early a series but seeing as my wife will drive it to work I dont mind the a+ if it means I can make it slightly more reliable
PostPosted: Wed Jan 28, 2015 9:48 am
Naturally aspirated, single or multi point with ECU is likely to your next decision :idea: :)
PostPosted: Wed Jan 28, 2015 9:51 am
Gonna go with the Hif44 included. :D maybe dual carb it lol
