It is currently Tue Jul 15, 2025 5:37 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 492, 493, 494, 495, 496, 497, 498 ... 568  Next
PostPosted: Sun Nov 23, 2014 3:23 pm
I put a new set of Mini Spares Centre's 1.5:1 `forged' rockers together.
They seem to have fixed 2 of the recent problems I experienced:
1. The adjusters supplied are now straight, not all bent,
2. The top of the rocker where the nut sits is now flat, and not cocked at an angle. No re-machining required. :)
PostPosted: Sun Nov 23, 2014 7:51 pm
Sanded back more paint to continue cut and polishing the entire car while awaiting parts to arrive from the UK. Definitely not the best weather in Brisbane to spend in the garage applying elbow grease from hours on end.
PostPosted: Sun Nov 23, 2014 9:45 pm
Rover Cooper
got the buffer out and started to polish up the car for The Grand Day out.
PostPosted: Mon Nov 24, 2014 1:02 pm
Started to reassemble the rear subframe for my '69 'S'. It's was a bit of a slog. Fitted the trailing arms,only to find I forgot to install the front mounts first.
PostPosted: Tue Nov 25, 2014 8:04 am
sent off the radiator to have the fins repaired, picked up my exhaust from having the hotdog removed and after a bit of persuasion got the headers away from the rest of the pipe
PostPosted: Thu Nov 27, 2014 12:00 pm
Finished today. She is finally ready for RWC. How much sweat in that bloody shed!img]http://tapatalk.imageshack.com/v2/14/11/26/aac5d4cca3726a0137e0bab1076178dd.jpg[/img]ImageImageImage
Black is the new Black
PostPosted: Thu Nov 27, 2014 1:38 pm
B-e-a-utiful, nice and clean, white walls in the future?
Nick
PostPosted: Thu Nov 27, 2014 5:15 pm
That's what I thought too, such a tidy looking car.
Can't wait to get mine back to get it looking complete again.
Just a pity about the Chelsea scarf in the background :P
PostPosted: Thu Nov 27, 2014 5:20 pm
Thanks guys. Sometimes it felt like it was never going to happen. I keep checking everything to make sure it still works. I will let you know how RWC goes. Luckily I have a great mechanic who is mini and classic car minded that is willing to accept the "character" of the car
You have to let me have the Chelsea scarf. I know what it's like to hurt! Maybe not now but we were crap in the 80s and 90s ☺️
PostPosted: Thu Nov 27, 2014 7:24 pm
Car looks quality, hope the RWC goes ok.
1972 Leyland Mini Clubman
2000 Honda CBR929RR
PostPosted: Fri Nov 28, 2014 1:10 pm
And as if by magic..........started her up this morning, coolant leak. Investigation ......water pump....... Removed radiator and fan 3 bolts come out no problems.......4th bolt shears off. Sometimes I hate this car! Have tried numerous times to remove sheared bolt from pump ( it's corroded into the pump as opposed to in the engine block. Just don't have enough room to get anything in there. Walk away, coffee and smoke and maybe cry!
PostPosted: Sun Nov 30, 2014 8:23 pm
Windscreen in. Rear also but I took it out again as I had forgotten the trim between rear window and parcel shelf :oops:
I will put the rear back in this week.
M
PostPosted: Sun Nov 30, 2014 9:17 pm
Topped up the tyres! Poor old girl hasn't been out in 8 weeks!
PostPosted: Mon Dec 01, 2014 1:51 pm
Spent about half hour polishing my knob....gearknob that is...mmm shiny
PostPosted: Mon Dec 01, 2014 2:04 pm
-=Insert witty knob pun/firefly reference here=-
Nick
