It is currently Tue Jul 15, 2025 5:45 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 491, 492, 493, 494, 495, 496, 497 ... 568  Next
PostPosted: Mon Nov 10, 2014 7:29 pm
I believe the current stanley are made by sidchrome.
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Fri Nov 14, 2014 5:18 pm
New red carpets fitted today. It's starting to come together at last
Black is the new Black
PostPosted: Sat Nov 15, 2014 4:59 am
Nearly ready to be shipped!
1993 R32 Nissan Skyline GTR
PostPosted: Sat Nov 15, 2014 6:40 am
Sent the wok in for Hydroblasting. I will post the finished result when I get it back Monday.
PostPosted: Sat Nov 15, 2014 3:28 pm
Spent the last 1 1/2 days trying to get the engine going - Had confirmed last weekend that the computer wasn't getting the signal it needs to activate the fuel pump, but still had to work all the way through the distributor electrickery, as hard-wiring the pump to ignition +ve didn't work either. Turns out the Primary coil is just out of spec, & the Secondary coil is stuffed, so I've re-connected the pump through the 'pooter & I'm off to Honda on Monday to order a new one...
@davem - I can only see one pic, but it looks good, real good. Is the bonnet vented? I've been looking for a louvered clubman bonnet for a while now, & decided I'll just have to buy a 2nd hand one from somewhere & modify it myself.
1.8L Sunshine - Legal, legit & lovinit
PostPosted: Sat Nov 15, 2014 5:59 pm
got it back on the road after a 5 month rest refreshed the engine replaced the broken pinion gear changed the drive shaft yokes to pot joints took it for a short drive still works :D :D
thanks to Peter Morris Jon Scott and everybody who helped
now to get the other 3 on the road :(
65 panel van Sprog
73 panel van Iggy
PostPosted: Sun Nov 16, 2014 2:51 pm
Clear coat on the LS alloys and rocker cover, pleased with the result!!
KBS Diamond Finish, highly recommended :)
PostPosted: Sun Nov 16, 2014 7:57 pm
2 new CV joints, all new GAZ lowered shocks and hilos all round, new thermostat housing and new green stuff pads on the front....
And one badly cut index finger.
64' 850 1275cc
PostPosted: Sun Nov 16, 2014 8:15 pm
Nice ,
You must of got some inspiration after seeing that Rocker Cover yesterday Richard :wink: .
PostPosted: Mon Nov 17, 2014 7:51 pm
Good range of products KBS. Love it.
5/72 Clubman Gt
PostPosted: Mon Nov 17, 2014 10:35 pm
Replaced rear windscreen chrome filler strip (what a right barsteward)
Started on the soundproofing (bonnet/ boot lid)
Replace rear speakers
PostPosted: Thu Nov 20, 2014 4:26 pm
Rego'ed for another year
$483.50 for a gio greenslip pension rego $0 today and $140 for nrma classic vintage insurance the other week for 12 months
PostPosted: Thu Nov 20, 2014 8:41 pm
Gave my fuel pump a refresh new points, banjosand seals. Gotta love when new parts turn up.
PostPosted: Sat Nov 22, 2014 4:20 pm
re-fit the fan and heater box after having it all out to remove the corroded fins from the core and check for leaks.
still need to do a cooling system flush cause there is a heap of crap in there. and figure out a heater tap.
PostPosted: Sun Nov 23, 2014 1:45 pm
Pulled the loom out of the car....its a bit of a mess....and a bit daunting thinking about rewiring/cleaning it up
