It is currently Tue Jun 24, 2025 2:45 pm
 Post subject: Windage tray
PostPosted: Sat Nov 08, 2014 10:32 pm
Do they make them and is it worth fitting one to a fast road 1360?
 Post subject: Re: Windage tray
PostPosted: Sun Nov 09, 2014 6:54 am
The jury is out on whether these things add any power- dyno results are inconclusive.
If poorly designed they can hold oil from getting back down to the pump pickup.
But it's generally agreed they are worth having on a race car- as they help keep the broken motor bits out of the gearbox if you lunch it. 8)
PostPosted: Sun Nov 09, 2014 8:14 am
Also keeps bits of gears from shotpeening crank rods and pistons when the gearboxes explode :(
PostPosted: Sun Nov 09, 2014 2:33 pm
Where can I get them?
PostPosted: Sun Nov 09, 2014 2:42 pm
This is the one that I have,
http://www.minimania.com/part/MIN500/Tr ... i-Cooper-S
PostPosted: Sun Nov 09, 2014 6:47 pm
I got one from here.
http://www.miniauto.com.au/home.htm
Comes flat and you have to fit it up but Ken? (I think) can help and direct you how to bend it up and fit it.
Oops what am i doing here?
PostPosted: Sun Nov 16, 2014 8:18 am
Windaghe trays work ina Mini. Fact. Seen to give around a 4BHP difference on rolling road tests. Because theMini gears rotate to form a vertical deluge of oil from the gearbox directly on to the crankshaft/rod rotating assembly, drag, and therefore bhp loss is inevitable. As for preventing oil getting back to teh sump - nonesense. It RETAINS oil in the sump to better feed the pick up. So much so that in race engines you only need to run oil up to just below the minimum mark on the dipstick. There is so much oil thrown around by the crankshaft assembly that upper lubrication is not affected when using a decent quality oil.
PostPosted: Sun Nov 16, 2014 7:35 pm
Looking at the pictures it looks like it would be very easy to make one. What material would be best? I'd assume mild steel would be good but alloy would be better (lighter) so what thickness would be suited if I used alloy, would 0.6mm be to soft and flex from the heat and spray of the oil?
Any opinions?
PostPosted: Mon Nov 17, 2014 7:52 pm
There was an American web site that had a pattern for one. I also think it maybe the same guy
that discovered that the Pulsar dizzy could be fitted. He may also been the same guy that came up
with the 123 Electronic Dizzy.
I went looking for his web site but with no luck, maybe someone else might find it.
PostPosted: Mon Nov 17, 2014 9:00 pm
this one?
http://www.starchak.ca/tech/pdfs/windage.pdf
Rover 214 atm ....
PostPosted: Tue Nov 18, 2014 8:09 pm
Thanks for that, should be much cheaper than 180 odd bucks for a "factory" item.
PostPosted: Wed Nov 19, 2014 7:02 am
KLAS wrote:
Well done! That's it.
PostPosted: Thu Dec 04, 2014 1:49 pm
I was reading an English Mag in the 90's and an article by our champ DV on windage trays and scraper blades was in it. I remember taking it out of the mag and putting away for safe keeping (dont know where though). It was on SBC's and he was getting big numbers of HP gains. What I remember from the article was the windage tray and scraper blade was about removing the oil cloud from the rotating mass. Some stupid amount of oil weight was spinning around with the crank and the scraper blade was removing the oil and the windage tray covered in directional mesh was also capturing oil as if flew past.
My 2c
PostPosted: Sat Dec 06, 2014 7:10 am
Safe places are usually really safe.
Safe from ever remembering where they are!
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Sat Dec 06, 2014 7:14 am
If its reducing the rotating mass then wouldnt it be more like lighteneing stuff?
Not so much giving you more HP but allowing the engine to rev up quicker.
5/72 Clubman Gt
