It is currently Tue Jul 15, 2025 9:21 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 489, 490, 491, 492, 493, 494, 495 ... 568  Next
PostPosted: Sat Oct 25, 2014 6:22 pm
Yes its nice on carbs. Glass doesn't strip the zinc off the nuts and bolts either.
PostPosted: Sat Oct 25, 2014 7:57 pm
Bought another. Well not a 'Mini', as such. :mrgreen: :mrgreen: :mrgreen:
PostPosted: Sun Oct 26, 2014 4:48 pm
Well you can't just leave us hanging, do tell or better yet pics :grin:
PostPosted: Mon Oct 27, 2014 8:31 am
I should have it at the Mill, if you're lucky!
It's a work in progress. :)
PostPosted: Mon Oct 27, 2014 11:18 am
I will be there if I am lucky :)
PostPosted: Mon Oct 27, 2014 1:28 pm
Everything crossed.
Good weather for it.
We will miss you if you aren't able to make it.
But I'll take plenty of photos of all the cars if you can't!
PostPosted: Mon Oct 27, 2014 3:10 pm
Updated my sig to resemble the current state of the car...
PostPosted: Mon Oct 27, 2014 3:20 pm
Ahhh the old pallet with wheels trolley!
I like it, I've not seen one in a signature before :)
PostPosted: Tue Oct 28, 2014 10:55 am
Pulled my spare Mk2S box down to fix jumping out of 2nd on overrun. This box has a 3.44 diff, where the Mk2S one in my Mini is running a 3.647.
I'm hoping the 3.44 diff will allow me to accelerate in 1st gear without short shifting @ 5000 due to A008 wheelspin, like I have to now.. :?
Sounds like a terrible problem to have. Wheel spin AND a spare MK2S box :!: :lol:
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Tue Oct 28, 2014 10:58 am
Minimadmarty wrote:
Added 3mm red pin stripes. I'm thinking maybe making the centre blue stripe completely red! Comments and opinions, positive or negative welcome 8)
Stripes look the goods. You would have to watch your step with those tailpipes sticking out that far. Trip over and scalp your shins!
5/72 Clubman Gt
PostPosted: Tue Oct 28, 2014 1:21 pm
I'd been having a problem with the clubby sometimes not wanting to start.... no power coming from the battery.
All i had to do to fix it, was wiggle the battery cables/terminals to sort it out.
so on Sunday I took the terminals off the wire and cleaned them up... cleaned the gunk out of the copper wires... then put the terminals back on.
since then... the 6 or so times i've driven it to/from work, sport, home its seems to have started up alot better and seems to be smoother at low revs.
am I just imaging it? or could a cleaner connection to the battery actually improve things like this?
1975 Hairy Lime/White Clubby
PostPosted: Tue Oct 28, 2014 2:48 pm
Yes it can you should have put the lead in boiling water or acid then vinigar
Acid would have made the thing like new
PostPosted: Tue Oct 28, 2014 4:36 pm
I was inspired by the talk between Mick and Morris1100 a month or so ago and finally sorted out a sandblasting cabinet. Still need to tidy up a few things with it but its a good start at least.
Now I just need to finish the rebuild off of my second compressor so I can keep up the air to it!
5/72 Clubman Gt
PostPosted: Thu Oct 30, 2014 3:29 pm
I profiled my NOS 21A1806 Hydrolastic Helper Springs as you do! :D
PostPosted: Sat Nov 01, 2014 3:00 pm
Pulled out both fuel tank , R/H one is leaking
Pulled out both rear hydro displacers , R/H one is leaking
Will change both rear brake hoses , as the L/H one has cracks
do this before the R/H one starts leaking
Need 2 new ball foot rubbers
Might install my new old stock tail light assemblies while the tanks are out
Don't want to be doing any of this , But that's the joy of the mini
Mark
Users browsing this forum: diecast, Phil 850 and 87 guests
