It is currently Wed Jul 16, 2025 2:03 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 486, 487, 488, 489, 490, 491, 492 ... 568  Next
PostPosted: Sun Oct 12, 2014 6:18 pm
started to put the motor back in after a minor rebuild with help from Jon Scott(justfangingaround)
65 panel van Sprog
73 panel van Iggy
PostPosted: Sun Oct 12, 2014 6:22 pm
Speedwell Racer wrote:
Test fitted 2 of my new mambas yesterday!
They stick out past the guards about 3 inches so I think I need to find some flares.
Still unsure on what type!
Cheers, Rhys.
They were never NOT going to stick out though, but geez they look great. My favorite wheel ever!
They do look sexy!
And I knew they would stick out so was expecting to get flares anyway.
Hence why I test fitted so I could measure up for flares!
Any rub, or does it sit high enough?
PostPosted: Sun Oct 12, 2014 7:13 pm
Mick wrote:
Hmm, you mean the timing gear cover or the one between the plate and the engine, I thought the one to the engine was the same? I should drop in the timing gear cover however. I'll get onto it.
Light grease will do, either type. Its more about having a grease in there then any particular type.
Hi again just dropped Hamish back to his Mums; watch out he has his 'L' plates now! I mean the one that goes between the engine and engine plate. Apparently both this gasket and the timing gear cover are different on the A+.
I'll use some Molly... I've had a new speedo for a while, and its got the slight wobbles. It could also be the speedo as some comments suggest that they are Chinese crap. I don't know, but speedo cables are cheap and its easy to replace whilst I have the front of the engine off.
Thanks for your help again.
PostPosted: Sun Oct 12, 2014 7:27 pm
Nothing, my truck needed fixing. But I did test fit my new seats on saturday.
PostPosted: Mon Oct 13, 2014 12:42 pm
They only just rub on full lock over a decent bump.
once the new engine is in ill be resetting the height anyway as the dump will probably sit rather low and ill just mod the guards to suit.
1977 Leyland Mini Van - Sold
PostPosted: Mon Oct 13, 2014 7:05 pm
Replaced wiring in engine bay and from fuse box to light switch after electrical fire last sunday made a mess of it. The light show under the dash looked good but the smoke wasn't. Also replaced the jet feed tube and nut at the bottom of the float bowl as it was leaking fuel straight onto the exhaust pipe.
DIFFERENCE BETWEEN A MINI & ANY OTHER CAR?
WHEN U PULL INTO A SERVO U FILL UP WITH OIL & CHECK THE PETROL.
PostPosted: Wed Oct 15, 2014 1:15 pm
Went to the local fastener joint to get the nuts and bolts required for my sub frame rebuild. turned out to be much cheaper than expected.
I never want to use crusty old fasteners again, sooo much nicer using new stuff!
Unfortunately they didnt have any M14 rod, so i cant finish off the front frames yet.
PostPosted: Wed Oct 15, 2014 11:15 pm
Rover Cooper
took the spark plugs out and found them all black and covered in black soot, so gotta find the vaccum leak thats causing the ECU to run very rich, now comes the fun, wish me luck...LOL :'(:'( :'( :'(
PostPosted: Sat Oct 18, 2014 6:31 am
drjbeam wrote:
Wired in a aldi 3 socket 2 USB 12 volt socket box to the aux fuse i stuck it on the side of the radio box
They come out today for $4.99 http://www.lasoo.com.au/catalogue/aldi- ... 0220682519
Cut off plug and put + wire to the aux fuse spare connecter and the - wire to the earth screw near the fuse box with all the other earth wires
Going back a bit here but I bought one of these from Aldi as we'll.
When I use it in my civic it causes static on the radio.
Does anyone know how to stop this (soldering in a capacitor, resistor thingy) :lol:
PostPosted: Sat Oct 18, 2014 10:41 am
I would check all your connections including the plug in the socket...poor connections can cause the same interference.
PostPosted: Sat Oct 18, 2014 11:10 am
Long hard fight with the needle bearings in the upper control arms. They almost had me beat, but eventually got out!
PostPosted: Sat Oct 18, 2014 5:08 pm
Put the battery on charge.
PostPosted: Sat Oct 18, 2014 6:45 pm
Started her up, gave it a few revs and showed off to my daughters Mates :)
PostPosted: Sun Oct 19, 2014 1:04 pm
Once again not mine but martys. Painting stripes on the bonnet.
I can see my mini plotting against me for cheating...
Must book aside some time for my baby.
Minis..
1976 van daily drive
1975 van
1968 deluxe in the shed
1967 deluxe high strung 1310
1959 austin healey sprite
PostPosted: Sun Oct 19, 2014 1:06 pm
Ooo.... Photos please :D
