It is currently Fri Jul 18, 2025 6:43 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 470, 471, 472, 473, 474, 475, 476 ... 568  Next
PostPosted: Tue Jul 22, 2014 9:25 pm
Drove it to work and back :)
PostPosted: Thu Jul 24, 2014 7:54 am
Reinstalled the bonnet stripes after paying for a professional cut & polish. For 16 year old paint she is looking mighty fine!
1998 Rover Mk VII
2001 Honda CBR 929RR (street)
2014 BMW S1000RR (track)
PostPosted: Sat Jul 26, 2014 4:18 pm
1. disassembled rear hubs after they were removed during the week. bearings need replacing. (timkens me thinks)
2. replaced wheel studs in the hub, they were a tad short.
3. Looked at the shocks, Right was ok left was a bit sad. new rear shocks.
4. accuspark installed during the week, dizzy went back in, runs sweet, need to check timing though.
5. little bit of a clean in engine bay need some degreaser.
Nick
PostPosted: Sat Jul 26, 2014 5:37 pm
Got a spark!
PostPosted: Sat Jul 26, 2014 10:57 pm
Made some hex brass bolts to hold my Dellorto carby onto the now water heated manifold. Better heat conduction, maybe... :)
Years ago I could have just gone and bought these, back when Australia made fasteners & engineering stuff. FA made here now... :(
PostPosted: Sun Jul 27, 2014 3:21 pm
Put petrol in and started up. Scared the dog and filled the garage with smoke. Need to turn it around so the exhaust points outwards to set the timing.
PostPosted: Sun Jul 27, 2014 4:01 pm
Finally got some half decent speakers installed in parcel shelf and fitted new mirrors I bought while in UK
PostPosted: Sun Jul 27, 2014 6:39 pm
Put the old girl up to take the front brakes off. Time for a ball joint check/service and I've got a CV Joint dust cover that's pushing a little grease out. While I am there, I have a set of adjustable bottom arms and tie rods to install :)
PostPosted: Sun Jul 27, 2014 8:21 pm
Nice jack there mick
PostPosted: Sun Jul 27, 2014 9:43 pm
Its an ATV jack. I'm a bit of a convert to this unit. It starts out super low, it jacks the car nice and high, a spread load, and locking points to take the weight off the hydraulic ram.
I still use Jack stands, but not today, I have to play with the tie rods and they get in the way, so I've used the ATV jack's lock point.
PostPosted: Sun Jul 27, 2014 10:44 pm
so do you just jack from under the sump? with it?
I've seen those jacks and wondered if they'd be any use for a mini...
1975 Hairy Lime/White Clubby
PostPosted: Sun Jul 27, 2014 10:46 pm
Yes, under the sump. Usually just long enough to get the jack stands under the front and that would be enough.
I wouldn't do that on a rod change however, without the remote you would be relying on the engine mounts in extension.
PostPosted: Sun Jul 27, 2014 11:11 pm
I use 2 holden torana rims each side and a mini rim in between and a block of 4x2 timber between the floor and rim as stands around where the wheel is in pic
I find it safer than axle stands when doing a job like that and i can lift all 4 wheels off the ground if i have to with 1 holden and mini rim on top in each corner of the floor
Good for bleeding brakes with all 4 wheels up in the air and i use a steel 4x2 hollow beam the width of the car between floor and rims on the back
PostPosted: Mon Jul 28, 2014 12:31 am
Milatsmadmini
drove all around Sydney all day :) spotted a cute white deluxe at the fish markets around lunch time!
PostPosted: Wed Jul 30, 2014 8:27 am
Richened the air fuel mixture to try solve my weak idle/stalling issue......
Didn't work but still gotta thank Mick! Previously if I were asked to richen the air fuel mixture I would have got a straw and blown bubbles in the tank. Already learnt a lot.
