It is currently Sat Jun 28, 2025 2:02 pm
 Post subject: Air trumpets installed
PostPosted: Mon May 16, 2005 10:20 pm
HAVE THE AIR RAMS INSTALLED :shock:
Report:
*Very, stupidly, ridicuously loud
*Heaps more torque....
I spin the wheels a lot easier coming out of corners in 2nd gear.... can be a bit of a pain... also, the smqaller wheels now probably wouldnt help a lot.....
peoples veiws???[/list]
68matic: "i havent seen much head in my life "
PostPosted: Mon May 16, 2005 10:35 pm
Are you talking about Carby Ramstacks? iwant some of these.. the short ones that can fit inside my K&N's :)
PostPosted: Mon May 16, 2005 10:38 pm
yeah.... they are so nice.... got a bag more torque with em....
PostPosted: Mon May 16, 2005 10:47 pm
Ha-Ha has 'em too.. my real short ones, no room for anything longer in a Ramflo!
PostPosted: Mon May 16, 2005 10:52 pm
mine are probably round 50mm long.... i had to take out some of the firewall on the passenger side to make them fit.... 8)
dont worry, I only cut two lines in and bent the section of the firewall back.... completely reversable
PostPosted: Mon May 16, 2005 11:09 pm
tom do they make that much of a diff compared to the foam filter?
Inconspicuously Conspicuous
PostPosted: Mon May 16, 2005 11:10 pm
I hacked mine big enough for a Ramflow with the GR manifold, but the speedo is in the way. Bugrit, I'll keep the Redline.. and sell the GR one. Gafmo has dibs on it. :wink:
PostPosted: Mon May 16, 2005 11:27 pm
:wink: :lol:
I didn't thing the ram tubes made that much differnace :shock:
PostPosted: Mon May 16, 2005 11:36 pm
Ram tubes just help to straighten out the air going into the carby right? Or do they really allow more air to be pulled through as well?
Jonathan
PostPosted: Tue May 17, 2005 6:48 am
Both.
A sharp edge effectively reduces intake diameter due to turbulence.
On a Weber or Dellorto, low speed running is improved with a stubstack or trumpet, as the venturi gets a better straighter airflow- helps it to control mixture.
Longer trumpets add to the induction length, this gives more torque. IF you have room in there... I don't!
PostPosted: Tue May 17, 2005 8:50 am
that's quite interesting :mrgreen: I didn't know that.
PostPosted: Tue May 17, 2005 9:54 pm
my boss has 100mm ones on his race torana..... god its a beast...
i need to get some socks and put them over the stacks
PostPosted: Tue May 17, 2005 10:27 pm
yeah i have 50mm ones one my webber and i'm putting filter socks over them. i hope it all fits
FOR SALE MInidlx, 1293, GR head, RE-13, GR worked Redline Manifold, 45 mm DCOE,pulsar dizzy , "S" Disc's, Mk II "S" box, 3.65 diff. Minator 10X6's On the loose
PostPosted: Wed May 18, 2005 12:19 am
They just move the torque lower in the rev range. They cannot produce MORE torque on their own. The torque is built into the motor by virtue of its specification isn't it?
Chris
Everything I like is either
PostPosted: Wed May 18, 2005 7:00 am
Yeah.. I guess what I should have said is they can optimise torque.
Another benefit is they can help stop fuel standoff fog from sitting outside the carb when you are running big cams..
Most race cars with Webers run long inlet manifolds which have a similar effect- ie increase indution length.
