It is currently Sat Jul 19, 2025 5:19 am
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 465, 466, 467, 468, 469, 470, 471 ... 568  Next
PostPosted: Thu Jun 12, 2014 9:40 pm
Thanks for that, yes the boot is unlocked. :D
[edit] Couldn't see any legible numbers stamped on the shaft, so I refitted it.
I can't find the spare one either. :x
Buggerit, instead of going for a drive to John's then having to clone a key, I'll just take the boot lock to my friendly local locksmith and get 2 keys cut for it. :lol:
[edit] A bad idea this, the locksmith (blacksmith?) fooked up the lock inside somehow.
So I've ordered a new one with keys, from Minis Plus.
I know a locksmith around the corner who has a shop in forge st blacktown J-Lock Mobile Locksmith 0296214318 father and sons do it
PostPosted: Fri Jun 13, 2014 8:29 am
I went to the one on Sunnyholt Rd.
When I've fitted the new lock I'll take the old one apart, now that I have a key.
[edit] new lock comes with 2 keys.
Last edited by drmini in aust on Sat Jun 14, 2014 7:52 am, edited 2 times in total.
PostPosted: Fri Jun 13, 2014 9:37 am
Get a second set cut and leave them on your daily driver key ring
Were lucky the keys aint chiped like keys for todays cars are
PostPosted: Sat Jun 14, 2014 2:01 am
"Lost" one of my chipped keys (with house, garage, mail box etc.) for the Jeep...looked everywhere...could not find the key ring...then one coolish Spring morning, as I took the waste & garbage out to the kerb, I threw on my hunting jacket.
Last wore the jacket in early December when I caught the last Mule Deer hunting days after coming home from OZ & NZ. YUP, the "lost" keys were in the right hand pocket!
We must be getting old Kevin!
PostPosted: Sat Jun 14, 2014 5:43 pm
Wired in a aldi 3 socket 2 USB 12 volt socket box to the aux fuse i stuck it on the side of the radio box
They come out today for $4.99 http://www.lasoo.com.au/catalogue/aldi- ... 0220682519
Cut off plug and put + wire to the aux fuse spare connecter and the - wire to the earth screw near the fuse box with all the other earth wires
PostPosted: Sat Jun 14, 2014 6:54 pm
Make sure it's well fused, Aldi... Hmm :)
I finished stripping down my 1100 motor in prep for rebuild. The crank looks good std std. Only going to need bearings and a light linish. Gearbox internals look pretty good too! Happy :)
PostPosted: Sat Jun 14, 2014 7:57 pm
I had 168 main jets in the Dellorto, before that I ran 165s. Goes better with the 168s, more is better right? So, I tried some 170s I had.
Was too rich.. ???! Tried a drill in them, found somebody has drilled these out to 175. :( 168s will have to do for now.
PostPosted: Sat Jun 14, 2014 8:06 pm
Solder them up and drill them again.
PostPosted: Sat Jun 14, 2014 8:24 pm
I've already binned them. They are only 4 quid to buy new from dellorto.co.uk . Or, I could drill out some smaller ones I don't use at GR's.
I will put the A/F meter on it tomorrow and go nail it up my favourite hill in 2nd gear. The 168s are on the money for road use I think. It even idles nice when warm.8)
[edit] Mixture at full throttle from 3500 to 6500+ is steady around 12.5:1.
Cruising about at part throttle it's about 13.5-14.5:1
Near enough for me. 168s it is. :D
It's idling good too.
Can't check mixture at idle because the sensor is clamped onto the tailpipe. Too much air going in and out at idle.
Last edited by drmini in aust on Tue Jun 17, 2014 2:51 pm, edited 2 times in total.
PostPosted: Sat Jun 14, 2014 10:52 pm
Make sure it's well fused, Aldi... Hmm ( yep wired in a inline fuse on the positive wire like I had before on a single one I put in a few years ago )
Probably come from the same place all the other brands come from over in China aka repco ,supercrap,dicksmith ect
http://m.supercheapauto.com.au/Product/ ... ket/224804 almost the same just one less USB for 16.99
PostPosted: Sun Jun 15, 2014 6:11 pm
Calipers re kitted, figured out where the relays will go.
One step closer
PostPosted: Sun Jun 15, 2014 8:31 pm
A few weeks ago I finally decided I was sick of the ripples down the driver side of the car, in the door and the rear quarter panel.
So I went at them and dinged them out carefully. Today I coated the rear quarter and door again in paint.
Now the front end is giving me the irrits too...
I suppose we'll go around the car and do a full 360 eventually :lol:
PostPosted: Mon Jun 23, 2014 3:52 pm
Got a ball joint splitter and a NON-CONTACT INFRA-RED THERMOMETER
http://www.tradequip.com.au/index.php?r ... uct_id=590
PostPosted: Mon Jun 23, 2014 9:48 pm
drove in to the pressure washer station and washed the engine without any water dispersant being applied to the dizzy.
love the pulsar set up with O ring and screws.
got fully blasted and still fired up immediately.
It's easy once you know how.
PostPosted: Tue Jun 24, 2014 8:28 am
Pulled out the LH tank to find an annoying fuel leak. After much stuffing around, decided it must be at the fuel sender O-ring. Replaced the sender with a different (But also not working) sender, slapped No.3 Gasket goo either side of the O-ring & put it all back together & left it to dry. Also replaced the very old 2-channel amp with an old 4-channel one I bought ages ago, but I forgot about it when we moved 5 years ago...... Found it the other day still in its' box...
1.8L Sunshine - Legal, legit & lovinit
