It is currently Sat Jul 19, 2025 7:46 am
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 460, 461, 462, 463, 464, 465, 466 ... 568  Next
PostPosted: Wed May 21, 2014 4:42 pm
After a good 4 hours port matching and grinding dropped in the minispares manifold and brand new SU, busy tuning it by trial and error.
much better, now we are at the mercy of the post waiting for the pulsar dizzy.
It's easy once you know how.
PostPosted: Wed May 21, 2014 7:55 pm
Get some decent plug and coil leads, you want inductive core ones that will last, not carbonised string...
I normally recommend Bosch, but-
Yesterday I went to Supercrap to get some loose Bosch leads and found the lead hanger rack in a bigger mess than their radiator hose bin (and that's saying something...). I left empty handed... :evil:
PostPosted: Thu May 22, 2014 9:15 am
mattsmadmini wrote:
drove to another cafe for breakfast :P
Love the colour - Great Moke 8)
PostPosted: Thu May 22, 2014 8:31 pm
Today, after 7 months of hard work, and a LOT of swearing in the garage. I said goodbye to my baby for the next week or so the new 1310 can be fired for the first time. Words can't even describe the excitement!
PostPosted: Sat May 24, 2014 5:19 pm
Bought another mini today. Only got it for parts but almost seems to good the wreck. Came with extra doors, 1100 remote engine and gearbox as well as 3 boxes of gearbox parts. Counted it up and there is enough to make 8 gearboxes! Bargain
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Sat May 24, 2014 6:39 pm
Started on ROO's suspension before we set out to drive across North America to Ohio & Wisconsin before heading home.
The rear is getting new knuckles, new doughnuts, new adj. height, new S wheel studs and new S drums, plus bearing packs and new seals/cotter pins. Adj. camber (only) brackets will be added later (using shims for toe). When finished...
The front will get new adj. lower arms & bushes, new adj. tie rods and new doughnuts. Then an alignment check & set up.
PostPosted: Sat May 24, 2014 6:43 pm
Fixed up the ignition circuit and went for a drive down the coast :)
PostPosted: Sat May 24, 2014 7:08 pm
Bought a new set of inductive core plug leads off GR, after having no joy finding Bosch ones at Supercrap.
At least these will fit nicely with my modified 43D Lucas dizzy. 8)
PostPosted: Sun May 25, 2014 2:31 am
DRMINI (Kevin),
Have ordered new clutch plunger, arm, spring, throw out bearing, pins, spring retainer...will I find any surprises in renewal when the WOK comes off ROO's Aussie unit??
Part of my "fit for service" prep before the 13,000 km. jaunt east & home...leaving 4 weeks today.
Hunter2 (Rick)
PostPosted: Sun May 25, 2014 7:57 am
Hunter2 wrote:
DRMINI (Kevin),
Hunter2 (Rick)
Hi Rick,
You may find the release bearing sits loose on the throwout plunger with a clip to hold it on.
This was an attempt by BL to let the bearing self-align with the thrust plate on the diaphragm, to reduce clutch shudder. Jury is out on whether it helped....
If you have a new plunger I'd fit it, but please try a file on it first. If you can file it, it's crap.
The cheapo ones coming from Minispares etc are rubbish, I measured their `hardness' at 1-3 HRC = very soft rubbish. Original BMC ones were well over 50HRC.
I have saved a few of these new soft ones by press fitting a hardened silver steel bush into them.
PostPosted: Sun May 25, 2014 1:57 pm
Glad I asked! Thanks Kevin...will let you know. Part coming from local supplier who buys from (sniff) Mini Spares among others.
PostPosted: Sun May 25, 2014 3:49 pm
Sanding all morning. About to put a coat of primer on it then the high fill primer....
so excited been sanding for weeks.
Minis..
1976 van daily drive
1975 van
1968 deluxe in the shed
1967 deluxe high strung 1310
1959 austin healey sprite
PostPosted: Sun May 25, 2014 6:26 pm
I look forward to the photo update :D
PostPosted: Sun May 25, 2014 7:27 pm
Tonight mate... got her covered in hi fill primer so next weekend its all sanding again...
Minis..
1975 van
PostPosted: Sun May 25, 2014 7:41 pm
Took it out the shed, washed and chammied, put back in shed.
