It is currently Sat Jun 28, 2025 1:57 pm
PostPosted: Thu May 12, 2005 11:52 am
Mini Mad wrote:
I seen it done both ways, the doc does it the second way described as well...
Reminds me i need to have a go at mine...
I don't do it that way ...
What I do is "modified rule of 9"
Say you turn the engine until valve #1 is on full lift, you can then adjust #8. But you will notice that an inlet valve is within a couple of degrees of full lift too. I turn the motor a few degrees more until it is just about full lift, then adjust its mate (rule of 9) at the same time as I do #8. This way I only have to move the motor 4 times, and I'm done. :wink:
oops.. :oops: well it was close :lol:...i knew it was different to the standard rule of 9 when you did it in half the time :wink: ...i'm still confused though :?
PostPosted: Thu May 12, 2005 6:15 pm
:lol: Funny how this thread has just come up now...Morris blew a head gasket today...so I may try the 1-2-3 Skip method this time :wink:
For those interested...between 1 & 2 and no it was not an ACl Gasket
PostPosted: Thu May 12, 2005 7:21 pm
hey gaf what gasket did u have in there? wonder why its always between 1 and 2...
acl have a 3 year/ 100,000km warrenty on them,, i think i will be using that in the future :D
1974 Moke - 998cc
PostPosted: Thu May 12, 2005 10:17 pm
I'm glad you asked...the the one time I will not recomend a Karcraft product is thier head gasket for a 998/1100 Silver head gasket...Prior t this we Did Blow one 3-4 :shock: so its not just between 1 &2 :!: I + other believ the it's just not good enought :!:
I will be replacing it with a ACL Head gasket which I believe will lasty considerable longer..the story will or will not...be told...Hayt Kazjim...how is my Old ACl going...Consideriang...you have turbo 998 and was notorias blowing Head gaskets :?:
Have we heared of one lateley....Nope...Karcraft... :idea: am I making a Point :!: :arrow:
Yer the Gemini and Cancer comes out in me some times :!:
PostPosted: Thu May 12, 2005 10:25 pm
:lol: @ gafmo...
PostPosted: Thu May 12, 2005 10:42 pm
:lol: Sod :wink:
Its jus one of those things in life
PostPosted: Fri May 13, 2005 5:43 pm
Damn man - I've never heard you complaining about anything before - me though I bitch all the time. I even bitch about me bitching.
But luckily have been using BK450s (1275head) as per Kev's advice and no problems, so no reason to complain but then I could bitch about the lack of an excuse to bitch?
PostPosted: Fri May 13, 2005 6:41 pm
My ACL's been good so far..touch wood..Have we had one of these blow yet?
PostPosted: Sun May 15, 2005 11:41 am
Okay I tried the 123 Skip to 5 method...Yer it does work for a starter....But you will have to adjust from thier with the 9 Method..
I tried and its not exact :wink:
PostPosted: Sun May 15, 2005 4:28 pm
you're doing it wrong boyo :P
PostPosted: Sun May 15, 2005 4:50 pm
Nar mate...thier is no way that 1,2,3 & 5 eg once ajusted to be correct
Sorry It close but you do need to re adjust with the 9 method
I did it as you have post :wink:
