It is currently Thu Jun 26, 2025 5:22 pm
 Post subject: Pick my Parts
PostPosted: Thu Feb 07, 2013 3:56 pm
Hey guys
Managed to have my first mini written off, saved the boot lid and the motor/gearbox! to get the motor running again l need to replace the following:-
Dizzy,coil,radiator,oil cooler,alternator, manifold. Ive got a budget of 4k for parts and would like to do some upgrades as my new mini is bog stock, still has the dealer stickers on it. Below is what l am proposing on buying from uk minispares, l am asking members to advise/recommend alternates if im heading down the wrong track.
Current Motor Specs
1310cc Morris 1100s motor
12.1 comp
straight cut gears
Torana LSD
mild cam
port and polish
Cooper S Calipers
Brass button Clutch
45 Webber
Here is my shopping list
Bilstein Shocks
Hi Lows
Maniflow Manifold
http://www.minispares.com/product/Class ... .aspx|Back to shop
Maniflow Exhaust
Alternator
Lucas Sports Coil
Radiator
Oil Cooler
Braided Brake Lines
Lightned Flywheel
http://www.minispares.com/product/classic/C-AEG421.aspx
Brake and Clutch Master Cylinders (ap minispares)
1.5 Roller Rockers
or
Geometry Kit
Anti Roll Bars
Thanks for all advice
Regards
Dave
PostPosted: Thu Feb 07, 2013 4:02 pm
Hey Dave,
Skip the full roller rockers and get the roller tip. The reason for this is that a bushed rocker has more contact area than a roller rocker does, which has all of the forces pushed against a couple or needles inside the roller bearing (no good).
Have you considered these instead? I am considering the LD rockers...
http://www.med-engineering.co.uk/catalo ... rocker-set
LD Version:
http://www.med-engineering.co.uk/catalo ... ld-rockers
I'd skip the oil cooler, no need for one. Have never run one in my car, unless you plan to race and are monitoring oil temps and the situation calls for one.
PostPosted: Thu Feb 07, 2013 4:05 pm
Sorry....
I say if its bog stock with dealer stickers. Leave it and Love it.
Keep it bog-stock.
will retain its value much better in my opinion
PostPosted: Thu Feb 07, 2013 4:34 pm
Bubbacluby wrote:
Sorry....
Keep it bog-stock.
I will be keeping the exterior and interior original just want some more out of the motor. I believe my car still has a delivery number on the front windscreen, chrome roof racks and a sun visor
PostPosted: Thu Feb 07, 2013 4:47 pm
[quote="Lillee"]Hey Dave,
LD Version:
Thanks mate will consider med just don't want to get stung multiple times on postage. Whats the advantage of the ld version?
Was only going to run a cooler as it previously had one
PostPosted: Thu Feb 07, 2013 6:50 pm
Not much difference for a road car, but I figure for $100 more you I might as well since it's already $340 right? :lol:
PostPosted: Thu Feb 07, 2013 9:12 pm
I got the LD ones. They look good, but i am yet to run them.Will post results once i have.
michael
PostPosted: Fri Feb 08, 2013 2:22 am
michael
Hey mate what was postage roughly? Had a look at there flywheels but confused what type do l need verto/ pre-verto???. They also mention pre a+ plus or a+plus when selecting parts what's the difference?
