It is currently Tue Jun 24, 2025 5:05 pm
Post new topic Reply to topic  [ 429 posts ]  Go to page Previous  1 ... 8, 9, 10, 11, 12, 13, 14 ... 29  Next
PostPosted: Wed Oct 17, 2012 2:10 pm
Milatsmadmini
That looks sex dude... gonna go so lovely!
PostPosted: Wed Oct 17, 2012 4:14 pm
zulu_warrior1976 wrote:
thats just a frame to mount the subframe on right?
It's the jig for the frame.. Frame is the less dodgey looking part inside it
V8 ute racing is treating me ok aside from takin all my money.. Heading of to the Gold Coast tomorrow
Cheers for the kind words guys
PostPosted: Thu Nov 01, 2012 7:00 pm
Got these in the mail today,
Protech coil overs. They are very neat looking little units!
Should have at least one day this long weekend to do some work
Sean
PostPosted: Sat Nov 03, 2012 6:15 pm
Hot stuff Sean!!
Those Protech units are very good quality and being alloy-bodies, they are light, dissipate heat quickly and you wont have to worry about corrosion!!
Good choice!!
Tricky
PostPosted: Sat Nov 03, 2012 7:38 pm
Yeah I'd also heard varying opinions on spax coilovers which were my other choice and I wouldn't have gaz after numerous issues with them in a race car we had. Protechs seem to be good quality and great value with a good amount of adjustment, not too much like most shocks, and have great customer support so looking forward to getting them in and seeing how they are! If all else fails they look awesome!
PostPosted: Sun Nov 04, 2012 7:18 pm
Today I fabricated a clutch slave mount which after coming up with several extravagant options, found a way of doing it in the most simple way while being strong! It's basically a peice of angle bolted to the gearbox casing then welded to some round bar which has been drilled and tapped to suit the rose joint with a small tab welded on which connects to whatever that box is on top of the gearbox (technical) which makes it super rigid! I then just welded some angle onto the original clutch arm and drilled a few holes for adjustment!
Looks too close to the box there but it's not..
I also sat the suspension and brakes in
And re fitted the engine, with the master cylinder reservoirs etc in to check for space
Will get the engineer to come and have a look at my work before I throw it all into the real car!
Can't wait!
Sean
PostPosted: Sun Nov 04, 2012 8:01 pm
That's some nice welding Meeni. It's all coming together nicely by the looks.
PostPosted: Sun Nov 04, 2012 10:06 pm
Sean why not just use the factory hydraulic slave cylinder?
PostPosted: Sun Nov 04, 2012 10:37 pm
This one works better with my master cylinder setup and I'm hoping will be a heavy pedal as opposed to the wet sponge you get with some cars. Also couldn't find a new factory slave cylinder. All of the 13b's were cable
PostPosted: Mon Nov 05, 2012 7:43 am
Fot futute reference, It's off a G16B or cultus sets up I think.
PostPosted: Mon Nov 05, 2012 9:20 am
Yeh the 1.6 and some 1.8s ran a hydraulic clutch, if you get the right one, it just bolts on, or so ive heard anyway.
:D
PostPosted: Mon Nov 05, 2012 11:00 am
Oh ok, meh, this looks cool and was probably cheaper too so ittle do
PostPosted: Mon Nov 05, 2012 11:53 am
Looks effective. On all the G13b powered minis I've seen, non have used the G16b hydraulic cylinder. My race car runs a mini slave cylinder, others have used the cable.
PostPosted: Tue Nov 06, 2012 11:27 am
That parts list is unbeleivable. I've never heard of protech, where are they from?
Hope the engineer gives it all the green light!
1963 850 - laid up
PostPosted: Tue Nov 06, 2012 1:59 pm
Protech are from the uk and available through Huddersfield mini spares amongst others..
Engineer is coming out within the next couple of weeks so fingers crossed, should be ok though
