It is currently Wed Jul 16, 2025 12:03 am
PostPosted: Thu Aug 30, 2012 2:56 pm
Just doing an oil change as final prep for Muscle Car Masters....
and found these pieces attached to the sump plug .. (not the 10c !)
Presume some circlip - but what ?
And what are the likely dangers ?
- gearbox 3 syncho (SCCR) ..
Was planning on pulling it all apart NEXT week anyway ....
.... but is it worth risking racing THIS weekend :? :?
:x :x :roll: :roll:
PostPosted: Thu Aug 30, 2012 3:47 pm
do you have pot joints / inner cv's ?
and the idler gear has a circlip on it too i think .. but i did think that they were the more common type with the holes for your pliers ..
do have circlips on your pistons ?
Beanie
I am the son of the STIG
HOTBRICKS
http://hotbricks.org.au/
'65 NCF MINI.....
PostPosted: Thu Aug 30, 2012 4:18 pm
Diff is a Quaiffe (LSD type) with Hardy Spicer Outputs....
(one thing I was changing next week --> Trannex)
Have straight cut idlers - with own bearing...
http://www.minispares.com/product/Classic/Gearbox/S_Cut_gears/Drop_Gears/C-STR31.aspx?150501&ReturnUrl=/shop/classic/Gearbox/S~Cut~gears.aspx
Pistons - Hypatecs .. which I think are just a press fit...
but keep the ideas coming....
I'm pondering if it is 22g278 - layshaft bearing... ( item #9 )
http://www.somerfordmini.co.uk/eshop/index.php?main_page=page&id=148
(if so - how has it escaped ?)[
PostPosted: Thu Aug 30, 2012 5:15 pm
then it could be the circlip from the output shaft on the quaife ..
so its the ATB type ?
HOTBRICKS
'65 NCF MINI.....
PostPosted: Thu Aug 30, 2012 6:19 pm
Looking at the pic, the only thought i have is a circlip as found on the diff/driveshafts.
So it might be just like Beanie suggests. I can't think of anything else in a gearbox or engine that it might be. All the gearbox and piston circlips are flat
You should be able to check by getting under the car and trying to pull the diff output flanges in and out of the diff. If they slide in and out, then you are missing the circlip.
They would only get into the gearbox if, when fitting the output flanges, the clip wasn't central and broke, then getting pushed into the gearbox as the flange slides in.
PostPosted: Thu Aug 30, 2012 9:43 pm
See what you are saying....
But this is the older style ATB
http://www.swiftune.com/Product/1104/early-14k-atb-differential.aspx
and uses the equivalent of these :
http://www.swiftune.com/Product/382/swiftune-10-spline-hardy-spicer-output-shafts.aspx
So much larger and robust circlip..... but will test anyways..
Bit of a puzzle...
PostPosted: Thu Aug 30, 2012 10:20 pm
Err .... this is a bit left field ......
but think I have it....
When all pieces put together form a perfect circle.....
appears may be part of a previous head gasket .....
.. but that's just weird.....
...... but feel a bit more relaxed about it now..... :? :?
Don't think it's the current head gasket (BK450)...........
PostPosted: Thu Aug 30, 2012 10:56 pm
The good thing is you have all the bits!
PostPosted: Fri Aug 31, 2012 7:16 am
I think you will find they are copper in the head gasket not steel
PostPosted: Fri Aug 31, 2012 8:47 am
Also they are not circular cross section, they are formed with a groove outside that grips the gasket.
Looks like a wire diff output shaft spring wire circlip to me... but how can it get into the sump? Unless the LSD has them inside, somewhere...
PostPosted: Sat Sep 01, 2012 12:01 am
The Mini King
It is Way past My bed time, But is it around the same dia as the bottom of a valve stem seal?
PostPosted: Sat Sep 01, 2012 12:18 am
does one of the breaks look sheared? If so then it's probably a circlip (sheared with cutters) if not then it was formed as a solid ring . Perhaps one to prevent something slipping of a splined shaft (sun gear?)
