yeah, it`s a pretty well packed with all the info you need, the common stuff like crank angle sensors & air & water temp sensors are all avaliable from the wrecking yards for cheap as chips these days, & obviously new if you were all anal/finicky/particular , but no need to buy new, they`re all so reliable & cheap 2nd hand, even the coil-over ignitors i buy 2nd hand from toyota Yaris or soarer & such cheap as chips (especially if you know the owner of the wrecking yard)
heads are probably better to buy from germany or the USA now-days, Aust is getting pretty sold-out these days, as there was a bit of a rush for them in recent times
(funny that)
, now if you rang any one of the Aussie bike wreckers now & you will get --> "You want this for a mini mate?" type answer
& yes, i`m sorry, i`m biased, the Turbo Injected twin-Cam bug has got me & i`m hooked
so if anyone asks me , i always suggest turbo inject them
they`re great as N/A too, don`t get me wrong,,, smooooooth as silk & much much faster than even the high-end, top dollar 5 & 7-ports, but Twinkys are still smooooth as silk while doin it
no big rough nasty race cams are needed
this is the beauty of the them, great power with wonderfully smooth power delivery "ALL" the way through the rev range
