It is currently Sat Jun 28, 2025 6:22 am
PostPosted: Wed Jul 16, 2008 11:21 am
I'm a bit over the hydraulic clutch in the mini.
Seeing as mine is leaking, I was thinking of converting to cable or mechanical clutch linkage.
This is ideal, but the price :shock:
http://www.shengineering.co.uk/pcmclutchkit.aspx
Has anyone done anything similar?
Pics would sure help my design process.
PostPosted: Wed Jul 16, 2008 2:03 pm
I know of someone who used to use one on a racecar, but had 'issues' with engine movement operating the clutch!
His solution was to solid mount the engine! Not such an option with a road car :lol:
Sir Alec! we are not worthy!
PostPosted: Wed Jul 16, 2008 9:37 pm
I think it would be possible but I wouldn't do it that way, looks to complex/too many parts to fail.
PostPosted: Wed Jul 16, 2008 9:45 pm
Cable would be better if you could adapt something from another car to fit . Without the flexibility of the cable or hydraulic hose there aren't many other options for holding it all rigid unless you're going to anchor your pedal to the block somehow to absorb the engines movements .
PostPosted: Thu Jul 17, 2008 1:27 am
Early Metros had an cable operated clutch.
Propaply the easiest way to go?
But don't ask me, where to get it from... Maybe from the UK...?
@sports850:
Or weld the ngine to the frame... ;)
cheers,
Jan
PostPosted: Thu Jul 17, 2008 1:44 am
Was that a verto clutch or conventional though ?
PostPosted: Thu Jul 17, 2008 7:43 am
verto,
i threw all the cable gear away when i robbed my metro of its engine, to be honest i liked the feel of the cable setup.... better then my verto and pre-verto hydraulic setup i have in the mini now
backyard performance............. Aint it the best
PostPosted: Thu Jul 17, 2008 9:35 am
awdmoke wrote:
Are all the bits needed for a mechanical conversion shown in this pic? I cant quite see how it would all hook up - either to an early or verto setup. . .I guess the rod on the right connects to the pedal and protrudes up through the bulkhead. . .the bronze bushed section of the gold anodised block is obviously a pivot point. . .but. . .
PostPosted: Thu Jul 17, 2008 11:07 am
It needs a linkage between the pivot & the clutch arm?
Not sure if that's included in the 200GBP kit
The pivot pin appears to be made to pick up one of the clutch slave mounting holes. Thinking that engine movement would cause too many issues unless the motor was solid mounted, as Graham pointed out.
PostPosted: Sat Apr 28, 2012 1:45 pm
The picture from my original post has disappeared, but the new photo has the full setup:
Oh, and the price is now 220GBP :(
PostPosted: Sat Apr 28, 2012 3:51 pm
I'd say a cable would be the better option to deal with the engine movement.
PostPosted: Sat Apr 28, 2012 4:36 pm
A clutch cable is a step backwards imo. Not to mention adapting one to suit a mini would be rediculous.
PostPosted: Sat Apr 28, 2012 4:53 pm
Does 220 Pounds really seem that bad when you think about it?
I just bought a new master cylinder, clutch slave and flex hose. I also busted the hard line so will need a new one of those:
Hose: $23
MC: $68
Slave: $38
Plus the new hard line I need made up, and the time to put it all in and bleed it.
Lets say that's $150, it's only another $150 plus postage for a mechanical thingy linked earlier +postage
And presumably you wouldn't need to replace that too often, or need to rebleed it
Seems okay to me price wise
You're so square
Baby I don't care
PostPosted: Sat Apr 28, 2012 4:55 pm
This space for rent
What's so bad about the standard hydraulic system?
I haven't changed anything (including the fluid :oops:) on mine in years, and it still works perfectly. Get the MC seen to, put a decent slave and hose on it and forget about it.
(Mine is a daily driver, that either aids reliability or proves the system is bulletproof, either way...)
PostPosted: Sat Apr 28, 2012 5:22 pm
The standard system is fine on a standard car, but the higher pressures and temperatures seen when racing shortens their reliable lifespan.
Anything above an orange dot pressure plate requires quite high hydraulic pressure.
This setup is probably consideraby lighter than the master/slave combination.
You would need to have the engine virtually solid mounted though for it to work. For this reason alone I've ruled it out for my road/track car.
