It is currently Fri Jun 27, 2025 3:20 am
PostPosted: Tue Dec 20, 2011 9:07 pm
Don't forget there are pudding stirrers and there are pudding stirrers.
The later moke as per Moly's is different to the old 850 style.
PostPosted: Tue Dec 20, 2011 9:08 pm
850 is magic wand, the puddin' stirrers came in 1969 on Mokes and Pov pack cars- was superseded by rodchange box when it came in 1973 or 4.
PostPosted: Thu Dec 22, 2011 10:56 am
Here's one fitted in a moke, I'm not sure what they did underneath though.
Don't think just bending the rod would work so maybe some sort of uni joint.
PostPosted: Thu Dec 22, 2011 5:20 pm
I can see the advantage in having a hole in the floor at that part of the floorpan.
You should be able to get a big jet of water to blast up the hole when you hit a patch of standing water at speed. :D
Is there any point to doing it or is it just another penis measuring exercise?
PostPosted: Thu Dec 22, 2011 8:14 pm
Yes the 'funnel' for the rod to go through could make things very wet inside
maybe there is some sort of rubber seal to stop water coming in.
I think the main reason is to give you a bit more room in the tunnel to get the exhaust
tucked up tight out of harms way if the vehicle is lowered or has a big exhaust or does lots of off road work.
On one outback moke trip the remote housing got smashed on a big rock near Birdsville so the moke driver selected 3rd gear and pushed started it until we got to somewhere where we could build a makeshift gear stick.
PostPosted: Thu Dec 22, 2011 9:00 pm
The sort of rubber thing you'r looking for is usually found on steering racks ;)
PostPosted: Thu Dec 29, 2011 9:56 am
We have had an internal Gear Change on the Race Car for the last 3 years.
We use a Sidchrome 1/2" Uni Joint ["stolen" from the tool box] fitted using roll pins adjacent to the Gear Box & a tighter fitting original joining sleeve to stop everything wobbling about.
The Steady bar is also used to stop the box jumping out of gear & the Gear change mechanism is mounted using 2 Mini exhaust mtg rubbers to enable it to move with the motor.
We lengthened both rods approx 150mm to bring the gear change further back & mounted the housing 100mm higher.
For something different we are now modifying an aftermarket gear change designed for a VW Sand buggy with reverse lockout.
[Mini= front engine ...VW= rear engine. Part solution is to fit the VW gear change in "back to front" plus some internal mods.]
This mod will only use a single rod... no steady bar...so will move with the motor on rubber blocks.
1974 1150cc Leyland Mini S racer,
1975 No motor Leyland Mini "ute"
1991 IPRA Honda Integra (in the build)
1995 Land Rover Discovery 300Tdi
CAMS Scrutineer
