It is currently Tue Jun 24, 2025 1:19 pm
Post new topic Reply to topic  [ 48 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Mon Mar 28, 2011 2:49 pm
Supercharged
if they're slower its because of the much longer gearing.
this however makes them fine to drive on the freeway, and you would be able to get better fuel economy.
PostPosted: Mon Mar 28, 2011 2:50 pm
This space for rent
The fuel economy of a carby'd A-series is actually pretty good considering. My warm 1100 with twin HS2's does between 6.5L/100km (highway) and 7.0L/100km (city), maybe creeping up to 7.5 if I'm revving the nuts off it all the time.
I agree that an injected A-series is heaps more like a 'modern' engine in its behaviour, but if you're after economy I'm not so sure it's worth the investment of $$ and time.
PostPosted: Mon Mar 28, 2011 3:14 pm
Harley wrote:
jb007 wrote:
...... 5.35l/100km or 52.79MPG for the older ones amongst us. Now to be fair, this was mainly freeway Km's between Werribee and Kew.....
Thats the same as what the 1.3i is claimed to be on the freeway cycle.
If at any point you're getting better economy than the factory, I'd be wondering if something is set too lean, wouldn't want to damage anything in the long run.
Here is my latest AFR Map. I only touch 16:1 when I'm higher in the rev range on a very trailing throttle. I've had it up to 16.5:1 but the car starts to surge very lightly, so I have backed it off.
With the factory cars I believe they don't run as lean, mainly because they are only running Narrowband sensors that only can tell the ECU if they are under or over the stoichiometric ratio of 14.7:1, whereas I'm running a wideband that can accurately measure between 10-19:1.
If I was rich, I would put in an EGT (exhaust gas temprature) probe to make sure temps are not getting to hot, but I'm not rich, so I guess I'll have to do with what I've got.
Further down the track when I've finished doing my mapping, I'll turn on the "Over Run Fuel Cut" feature. This cuts the fuel when you lift off the throttle... my little Renault has this feature and it works very well. :)
PostPosted: Mon Mar 28, 2011 3:16 pm
simon k wrote:
awesome - well done :D
Thanks. We should have another dyno day soon! Tim if your'e reading this! :P
PostPosted: Mon Mar 28, 2011 3:18 pm
I'm pretty confident that I use more fuel in my weber 1275 than my SPi 1275. :D
Seriously though, with a few mods you can make the SPi run significantly better. A set of extractors and dumping the catalytic converter makes a big difference to the drivability.
2008 Prado GXL
PostPosted: Mon Mar 28, 2011 3:26 pm
I know the Weber I had fitted to my MGB back in the 70's sucked juice like no tomorrow, but then again it was only 16c/litre! (20c/litre for 100 Octane).
I'd love to have a drive of a SPi or even a MPi to compare with my conversion. :oops:
PostPosted: Mon Mar 28, 2011 3:57 pm
This space for rent
Oops, I should have said "... an SU carby'd A-series ..." :oops: :lol:
PostPosted: Mon Mar 28, 2011 5:46 pm
How different is the stock spi/mpi injection set up to your aftermarket injection set up jb007?
PostPosted: Mon Mar 28, 2011 6:10 pm
Good question; hope I can answer it... (I'm not an expert in these things)
SPi is more like mine, only one injector is used, hence the term Single Point Injection. My TBI uses a wideband O2 sensor compared to the narrowband used by SPi & MPi. My setup is using the SU HIF44 as a throttle body, whilst the SPI/MPI have dedicated throttle bodies. Difference in airflow... don't know but I do know that a HIF44 has more than enough flow capacity for my state of tune.
The MPi is the most advanced in that it was conceived to overcome the Siamese port problem of charge robbing between the outer and inner cylinders. To achieve this they use 2 very large flow rate injectors (roughly 4 times the flow rate required) and a camshaft sensor so that they can precisely time the injection window to coincide with the opening of the inlet valves. The large injector size is required because the intake window is very small, hence a very short large charge load is required. With a 'wet manifold' system eg TBi and SPi, fuel can be left in the manifold just waiting for the next inlet event.
I have no first hand experience with the SPi or MPi systems, so I cant say what benefits they provide in practice over mine, but I know my setup has transformed my car. :D
Hope this has answered your question?
Edit: Sorry that last sentence sounds a bit rude. :oops: What I meant to say was; I hope I have answered your question.
PostPosted: Mon Mar 28, 2011 9:02 pm
Here is a small video of my injection set up ... It uses two 33mm throttle bodys off a Kawasaki ... With RX7 injectors this is my first start up cam is Kent megadyne 296 so it's a little rich and lummpy
Enjoy
http://i149.photobucket.com/albums/s42/ ... 8ff00d.mp4
I am the son of the STIG
HOTBRICKS
http://hotbricks.org.au/
'65 NCF MINI.....
PostPosted: Mon Mar 28, 2011 9:06 pm
I put a 1275 SPi motor in my van (now sold :cry: ). I rebuilt the motor, gave it a mild cam (SPi grind from Steve at Brickworx, now rare I'm tipping), a set of extractors and all new sensors and a proper tune. It generally ran at about 6-6.5 litres per 100kms, and whilst I don't thrash my cars (race car excepted), I am not really light on the right foot either. It was my daily drive for 2 years, and I really miss it. Would do it again if I had the time. Good luck.
1964 Morris "Cooper S" Group Nb Racer
1965 Morris 850
ex 1967 Morris Cooper S
ex 1969 Morris Van (Rover SPI running gear)
PostPosted: Mon Mar 28, 2011 9:17 pm
Enjoy
I love the sound... definitely has a cam! 8)
Are you using a MS ECU?
PostPosted: Mon Mar 28, 2011 9:23 pm
jb007 wrote:
Enjoy
Oh yeah!!
That sounds sweet.
I'd love to hear that screaming through the hills on a quiet Sunday afternoon. :twisted:
Image Image
PostPosted: Mon Mar 28, 2011 9:39 pm
jb007 wrote:
Enjoy
I'm using a haltech F9 it's fuel only but sure is alot of fun .... Still needs a bit of work and a good tune
HOTBRICKS
'65 NCF MINI.....
PostPosted: Thu Mar 31, 2011 11:02 am
I have a Van with a 1996 spi with aircon.
My fuel consumtion is 6.3lt per 100kms. I drove it spiritedly around town to see how bad the economy could be and got 8.3lt per 100kms. This was all with aircon on. I believe if i drove it on the Highway without aircon i could get into the 5lts per 100km average. Really reliable engines. very smooth engine. Bugger all maintainance.
I didn't do the conversion but it would be the easiest injected conversion when you consider ALL aspects including rego and insurance etc.
p.s. the aircon is great even in 40 degrees. If your car is for daily driving get a front cut with aircon.
V8's aren't cool!!!
Users browsing this forum: Bing [Bot], Majestic-12 [Bot] and 85 guests
