It is currently Fri Jun 27, 2025 2:39 pm
Post new topic Reply to topic  [ 219 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 15  Next
PostPosted: Tue Jan 25, 2011 12:31 am
we need a like button & tissue button....... 8)
PostPosted: Tue Jan 25, 2011 6:26 am
I have been looking at these kits for a while, are you going for the su or webber? They seem to be very good value, i am thinking the webber kit.
PostPosted: Tue Jan 25, 2011 11:31 am
Already have an SU kit sitting in boxes waiting for an engine. :)
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Thu Feb 24, 2011 9:39 pm
A bit more progress.
I fitted the pistons into the block, fitted the crankshaft, camshaft, oil pump and new twin row timing gear. Now need to track down a dial gauge so I can check the camshaft timing is correct.
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Mon Feb 28, 2011 9:06 pm
Some photos from last few days work on the engine
Minispares head studs fitted
Head and rocker gear fitted
I was dissappointed I had to file down the centre spacer on the Minisport rocker gear by a few thou so as to stop the binding of the 2 inner rockers and pack out the 2 outer rockers with a thin washer so as to reduce the play.
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Tue Mar 01, 2011 8:55 pm
Did a trial fit of the Supercharger tonight.
Lines up on the head studs very nicely and seems to fit well. :) :)
Now for the rest of the engine and gearbox.
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Tue Mar 01, 2011 9:40 pm
Mine is pretty much complete but everyone I have spoken too tells me not to run the pulley without a damper. I argue that they would come with it if required but folks with lots more experience than me say otherwise.
I have had a damper attached to the pulley, though now it fouls the engine mount so need some mods done there. Seriously thinking custom gilmer pulley may be the way forward.
1965 Riley Elf
1974 Ex Army Moke
1997 Rover Cooper
2002 JCW Cooper
2003 JCW Cooper S
PostPosted: Wed Mar 02, 2011 6:40 am
This engine originally had a crappy tin pulley with no damper and I was going to buy a new harmonic balancer but obviously that wouldn't fit now.
So far no one else has advised against just fitting the pulley.
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Wed Mar 02, 2011 6:35 pm
IMO crank life in a road 1275 or bigger will be seriously reduced without a good damper fitted. Vizard agrees. read da book....
You might get away with it in a hillclimb or drag car where engine life is measured in hours... :lol:
PostPosted: Wed Mar 02, 2011 7:58 pm
been made me on & press fitted mine onto a A+ pulley.
no problems there.
he did a awesome job..
i would talk to ben92
PostPosted: Wed Mar 02, 2011 8:01 pm
At this stage the car will only be used for weekends. My Cooper S which was restored 15 years ago has only 22000 miles since the resto, so I expect this car will be used in a similar fashion.
But I will check with GR when I see him next, although he has seen the kit and made no comment on the pulley at that time.
I must admit I can't see how you could fit a damper to the pulley as there would be no space between it and the radiator?
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Wed Mar 02, 2011 9:02 pm
This space for rent
Ask BALLISTIC how long his roadie 1275 lasted when his $$ Romac damper shat itself on the way home from the Asparagus Job in '09. I know, I was 8 hours behind him on the road, and bought a good s/h standard one in Narellan and ferried it down to him ;)
No way I'd run anything bigger'n a 998 without a damper. Even a tuned 998, I'd probably fit one for the peace of mind...
PostPosted: Fri Mar 25, 2011 11:10 am
I finished checking the cam timing and it is pretty close, works out to be about 111.5 degrees. GR advised should be OK, needs to be 112.
Inserted the new push rods and fitted the head and rocker gear then torqued the head down to 45lbs.
Next step is to check the gerabox and fit the central oil pickup and 4 pin diff.
Gearbox feels pretty good as it has only done about 3k since purchased as a reco unit from Mini Car Clinic.
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Sat Mar 26, 2011 11:50 am
you're better off going to 112.5 or 113 to allow for the chain to stretch
what compression will it have?
PostPosted: Sun Apr 24, 2011 8:41 pm
Some more progress, although much slower than anticipated. :(
Pulled the gearbox apart and checked it, only found a worn layshaft which is now replaced with a new toughened version.
Reassembled with a new central oil pick up
4 pin diff and 3.2:1 crown wheel and pinion.
Cleaned up all the alloy parts ready for painting.
This shows a before and after shot
clutch cover
Gearbox placed onto the engine and bolted into place.
Now ready for painting before all of the ancillaries are added
I also purchased a trigger wheel kit which I am adding onto the pulley and then configuring with a megajolt ignition kit.
1969 Cooper "S"
1967 Mini Deluxe
