It is currently Tue Jun 24, 2025 6:24 pm
PostPosted: Thu Mar 25, 2004 11:38 pm
I'd say approx 230 to 250kms - 1978 - 998
 Post subject: How many ks on one tank
PostPosted: Tue Jun 08, 2004 11:54 pm
I get 400 ks easy out of mine
:lol:
PostPosted: Wed Jun 09, 2004 8:58 am
one pair of shoes per month....
PostPosted: Wed Jun 09, 2004 10:31 am
Mine van's a 1132cc with 1.5" SU, extractors, 12G295 head, 731 cam and leccy ign.
I get 240km+ around town and up to 270km on a long highway run. 25L tank.
My fuel gauge does not work, so I generally just fill up every 150 miles. It saves embarrasment when it runs out on the fast lane of the Geelong Freeway :oops:
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Wed Jun 09, 2004 11:46 am
I've been getting about 270kms from about 19-20L, Ive got a stock 1100 74 leyland (oh a redline airfilter and badly tuned to probably run rich, closest thing to a mod :) ) And that's with me revving out most gears, do alot of 80/90 zones though but I thought with a 4 speed that would ruin economy, less stopping I guess.
Do you guys fill it up till it clicks or until it dribbles out?
I normally pull it out a notch but never put more than 21L in and that's with the gauge about 1/2 cm below empty.
It sounds like changing the carbies, exhaust etc kills fuel economy big time. Guess that's what you get with carbies vs Fuel Injection.
PostPosted: Wed Jun 09, 2004 2:13 pm
I put 25.5L in the other day! It was fairly empty.
I guess I'm going to have to write down the milage when I fill up next time.
PostPosted: Wed Jun 09, 2004 3:18 pm
When Morris was not sick I'd ask the wife to watch how we got. But she kept forgetting. Once Morris is on the road again its something I want to check again
CHeers
PostPosted: Thu Jun 10, 2004 1:40 pm
I should have said I usually only have to put in 20L-22L to fill it after 150 miles (240km) around town. I worked out I get 9L to the 100km around town and 7L to 100km on a highway run (3.65 diff, steady 100km/h). This compares pretty well with a modern tin-box hatchback.
I usually fill it until the pump clicks off, then fill it slowly until the fuel is up to about 2"-3" below the top of the filler neck. Vans have a longer filler neck than a sedan.
Brett Nicholson
1966 Austin Mini
1973 LR Series 3 88
PostPosted: Thu Jun 10, 2004 11:46 pm
Drive it till it stops then worry about fuel economy!!!
