It is currently Sun Jun 29, 2025 7:28 pm
 Post subject: Turbo And Intercooler
PostPosted: Sun Mar 20, 2005 7:03 pm
Does any one know or what are the recomendation on what sorta/size turbo to use on an A+ ?? I think im gonna go with a garret turbo. A custom manifold will be made to mount the turbo above the clutch to save me from hacking the cross member..
Daniel
Life's a garden.... Dig It!
PostPosted: Sun Mar 20, 2005 7:24 pm
there are a few options,, do you want brand new ($900-$1900) or second hand ($200-$900)???? what spec motor is it going to be, intercooler?
1974 Moke - 998cc
PostPosted: Sun Mar 20, 2005 9:08 pm
Well i have an A+ motor and box, not too sure about the internals as yet. And i was looking to intercool it as well, but as we all know it always comes down to the determining factor $$
So what model would be suitable for a 1275 A+?? G2 G3 G25?? OR ?
Daniel
PostPosted: Sun Mar 20, 2005 9:12 pm
a t25 is pretty small and should boost pretty early on in the scheme and unless you wanna run 20psi, should cope ok... that what i have...
68matic: "i havent seen much head in my life "
PostPosted: Mon Mar 21, 2005 10:10 am
hijack. hey daniel where did u get ya kit from ?
lookin for another clubby
PostPosted: Mon Mar 21, 2005 11:50 am
Just to add to this turbo discussion - how hard is it to convert a HIF to blow through use for a turbo?
Mini - The Wizardry on Wheels!
PostPosted: Mon Mar 21, 2005 12:17 pm
Volodkovich wrote:
how hard....
fcuking......... otherwise everyone would.
PostPosted: Mon Mar 21, 2005 12:32 pm
Midel in Sydney can do it- someone posted prices here a while back. I think around $250 to convert? $500 for a new turbo one! :shock:
PostPosted: Mon Mar 21, 2005 12:50 pm
Just read vizards bible and he says you need to put a restrictor in the inlet, seal the throttle spindle and run a line to the float chamber so the carb effectively 'sees' the boost...
How did kazjim do it to his boosted 998?
PostPosted: Mon Mar 21, 2005 12:57 pm
for a 1275 with unknown internalls and compression i would run a garrett t2 from a turbo pulsar or exa... i would run it on the lowest boost the wastegate will let you (think there set to 5 or 6psi)... The reason i say the T2 is that it will come on boost around the 2000-2500rpm mark and most are only oil cooled so alot easier to fit a motor that wasnt made for a turbo. basically saves running water lines to it.
Im running a T25 on my 1330 toyota motor in my mini and boost comes on around 3000rpm and hits full boost (12psi) by 4500rpm. On an a series add another 500rpm-1000rpm i think.
Then there is always the GT17 and GT20 turbos found on late model saabs, same flange as the T2 turbos but start boosting at 1500rpm :shock: These will boost to over 16psi.
Gt25 would be way over the top for an a series, as on the starlet motors these will be just as laggy as a normal t25 but will hold boost over 20psi. Big dollars too.
1974 Moke - 998cc
PostPosted: Mon Mar 21, 2005 1:09 pm
"How did kazjim do it to his boosted 998?"
Shelled out for a Metro Turbo HIF-6 ....
Took a while to find one, but hey are out there... got mine from FLorida (US!)
J
PostPosted: Mon Mar 21, 2005 3:31 pm
Just to clarify the motor isnt in the car as yet...
And i realy want to feel the oommmph kick in late, i want to feel the push back in the seat :twisted: so where would that leave me? I guess that would leave me with a lot of lag?
PostPosted: Mon Mar 21, 2005 5:10 pm
Then there is always the GT17 and GT20 turbos found on late model saabs----Sounds Interesting 8) I wonder on the Ching Ching
Gordo = Lager
:lol:
PostPosted: Mon Mar 21, 2005 5:13 pm
GT 20 $699 US I would Say
http://www.turbocalculator.com/view-pro ... 02-001-002
PostPosted: Mon Mar 21, 2005 5:37 pm
Ebay....
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&category=43808&item=4536942254&rd=1
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&category=32063&item=4535149507&rd=1
Worth a try at the $$$ .... personally, you arent flying it to the moon, you dont need a HUGE turbo.... :D
unless you WANT to go absolutely mental ....
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&category=72478&item=4536433499&rd=1
J
Users browsing this forum: No registered users and 23 guests
