It is currently Sun Jun 29, 2025 6:24 am
 Post subject: Dead fuel guage cause?
PostPosted: Tue Jun 01, 2004 7:12 pm
Is there a certain part of the fuel guage system that usually fails (like the guage, sender, etc)? Or is it just test it and see? How much for replacement guage, sender? This is in a 1970 van, by the way.
PostPosted: Tue Jun 01, 2004 7:19 pm
ive had 2 minis and both the fuel guages didnt work. Both had stuffed senders, Karcraft have new ones for around $60, for vans to i think.
1974 Moke - 998cc
PostPosted: Tue Jun 01, 2004 10:06 pm
i know how to fix it!!! :D
hire an exorcist to scream "OUT, OUT FOUL PRINCE" over and over at the van til the fuel guage starts to work....easy! :wink:
PostPosted: Tue Jun 01, 2004 10:20 pm
Yeah `usually' it's just the sender worn out from old age.
But, I bought a NEW 130MPH S speedo a while back from Minispares- its fuel gauge carked it in 3 months. Totally open circuit. Not worth shipping it back to UK. :x
PostPosted: Tue Jun 01, 2004 10:30 pm
I'll start with the sender, then work my way forward then. ;)
PostPosted: Tue Jun 01, 2004 10:35 pm
If you ground the sender wire at the tank it should read full. :wink:
PostPosted: Wed Jun 02, 2004 9:51 pm
My gauge had been dead for a while (refer my post http://ausmini.tziworld.com/viewtopic.php?t=705). I fixed it with a new sender, $65 and about 10 minutes work :)
PostPosted: Thu Jun 03, 2004 8:31 am
hi guys,
I don't mean to hijack this thread, but it's one i was going to post soon myself!
My fuel gauge didn't move off empty so i replaced the sender, now it reads 3/4 full when empty, and full when 1/4 tank or more? :roll: :roll:
Any Ideas? Please?
(oh and i have tested it with the sender unit out of the tank, so I know that it does this when the sender is reading at the right level!)
Matthew
PostPosted: Thu Jun 03, 2004 8:51 am
Maybe it is the wrong sender. You can connect a multimeter to the wires to read the ohms (restistance) and move the sender up and down and write down the resistance when full, half full and empty and make sure that they are correct for the guage. If the resistance is wrong or doesn't change when you move the sender than it is faulty or incorrect, you will need to find out the resistance values for your gauge to match up senders.
Have I totally confused you!
Andrew
1974 Leyland 998 Clubman S
Red with White roof.
In need of work (Work being done!)
SWEET!!!!
PostPosted: Thu Jun 03, 2004 3:48 pm
Sounds like a good idea, will try out over the weekend!
Any idea where i can find out what the resistance should be at different readings for any particular gauges do you?
Mine is a Morris 68 deluxe.
Matthew
PostPosted: Thu Jun 03, 2004 4:04 pm
I am not quite sure, prob. need to do some reserch on the WWW. At work I usually hook the sender into the gauge and see if it works that way, sometimes the gauges come with the resistance marked on them (I work on earthmoving equipment so they are a bit larger than the mini though!!!). Maybe someone else knows. :lol: :lol:
Andrew
SWEET!!!!
PostPosted: Thu Jun 03, 2004 5:09 pm
Early 850 fuel gauges and senders worked the opposite way. The senders for those are held in with 6 screws, not a bayonet ring.
