It is currently Fri Jun 27, 2025 5:32 am
Post new topic Reply to topic  [ 248 posts ]  Go to page Previous  1 ... 13, 14, 15, 16, 17  Next
PostPosted: Mon May 25, 2009 11:07 am
I used the Mini speedo with a custom cable made up using starlet gbox end and mini speedo end and got the speedo recalibrated. By memory it was around $160-180.
My odo is slightly out, but I'm not too concerned about that. I could have gone the little gearbox as Mearcat said, but they are anywhere from 150 to 300, then I'd still need to have the cable made too.
Mind you I didn't have a starlet gauge cluster to play with. :?
-James.
Toyota 4EFTE Powered Minivan.
PostPosted: Mon May 25, 2009 12:19 pm
my whole operation cost me approx $70.. I can change it to suit any wheel combo I like :P
Alternatively... install a bicycle computer!.. :D
PostPosted: Mon May 25, 2009 12:23 pm
What instrument cluster did you use? From what car?
-Alan
PostPosted: Mon May 25, 2009 1:46 pm
what are those wheels? cheers.
PostPosted: Mon May 25, 2009 2:26 pm
pubudug wrote:
Next items on the list:
1) fit me brand spanking new 13x6 minilites on with yokos
-Alan
PostPosted: Mon May 25, 2009 6:33 pm
Yeah. I like the fact that my car looks like an ordinary mini until I open the bonnet, but the way I did it definitely has limitations. I bet your dash is easier to read and the lighting and circuitry are more reliable too. There are many ways to do it. 8)
-James.
PostPosted: Tue Aug 04, 2009 8:06 pm
Hi guys,
its been a while since an update..
Been drilling out non critical bits and pieces to reduce some weight.. including the back seats! :D
I made a new log manifold for the car!
I've installed the SAFC and just when I upped the boost to 12psi, the clutch started slipping! :evil:
I am after a new clutch and want to do it myself..
Can you guys please give me some guidance as to what brand etc I should look for?
-max HP less than 200fwhp
- pedal effort should remain the same
Pubs
PostPosted: Tue Aug 04, 2009 8:14 pm
Exedy
PostPosted: Tue Aug 04, 2009 8:18 pm
Im planning on fitting one of the exedy jobs off ebay you mentioned on the starlet forum. Or is there a supplier for brass button clutches?
Simplify and add lightness
PostPosted: Tue Aug 04, 2009 8:21 pm
whats this brass button business? sorry new to all of this! :oops:
PostPosted: Tue Aug 04, 2009 8:26 pm
Did a quick bit of research, and theyre high power clutches. The downside is a really heavy clutch to put a lot of power through it. Thinking more closely i dont think that would work as that much power would probs shear the driveshafts.
But dont quote me, im still a rookie on clutches.
PostPosted: Tue Aug 04, 2009 8:52 pm
I wouldn't get an exedy Heavy Duty they are only 30% uprated.
An exedy cusioned button would the the best choice maybe, i've used a custom cushioned button on Dan's car and it's probably the best.
Part No.
TYK-6924 HDCB
I have the strongest clutch, 4puk ceramic button (most are ceramic now) and it's great on the track but PITA on the road. You do get used to it but i would prefer a cushioned button on the road, but on the track i prefer the button. They are on off and very very harsh. eg. My wheels spin before the car moves but just engaging the clutch.
Think of the clutch as a fuse of sorts, if you are slipping with your current clutch a stronger clutch will push this force out through the gearbox, diff, shafts, cv's etc. Which is why i broke a couple of shafts.
I've done a few thousand km's now on the new shafts with no problems. Will be taking it to wakefield in oct so will see how it holds out.
PostPosted: Tue Aug 04, 2009 9:07 pm
How were the new shafts compared to the old shafts? Were they a different design or a different material?
Joe
PostPosted: Tue Aug 04, 2009 9:11 pm
I had an Exedy cushioned button clutch on my 305rwhp R33 Skyline and it drove beautifully on the road with a very light pedal. I would definitely recommend it.
-Alan
PostPosted: Tue Aug 04, 2009 9:13 pm
4130 was used and the shaft diameter was made smaller than the root or the spline allowing it to flex instead of shear.
