It is currently Sun Jun 29, 2025 11:58 am
Post new topic Reply to topic  [ 34 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Fri Mar 04, 2005 1:54 pm
i got raimflos too but id like the look of those much better :)
Piper Cross here also Exactly the same as Makka's on a HIF 44
Yep theyt can be clean and re Oiled..Which Remindes me I have to do that again
PostPosted: Fri Mar 04, 2005 1:56 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
oh the price chit i think they wer maybe round 60 bucks each from midel in sydney they are at oh god someone help me frasier ave is the the name of the street lakemba maybe ??
PostPosted: Fri Mar 04, 2005 2:05 pm
Midel... 4 Frazer Street Lakemba NSW 02/9759 5598 Fax 02/9758 1155
Speak to Bill (SIVO) I highly recomend them and Sivo..say you are from Ausmini..Please :D :wink:
PostPosted: Fri Mar 04, 2005 2:20 pm
go to a motorbike shop and have a look at the piper cross filters they have, thats where you get em.
aaron
PostPosted: Fri Mar 04, 2005 2:39 pm
K & N are OK if you have the room. Otherwise, I like Unifilter socks, or Ramflo with a `Finer Filter' element in it (can't buy these elements now but I've got a couple..) :wink:
Whatever... don't run a road car with no filtration- it'll wear out before its time! :cry:
PostPosted: Fri Mar 04, 2005 5:17 pm
hmm....looks like I'll have to toss a 3 sided coin to decide, what are the prices on these suggestions?
PostPosted: Fri Mar 04, 2005 10:38 pm
do any of these filters specify their ashrae rating (excuse spelling) which is a standardised filtration test on which all filtration is based on, including the australian standards rating. what you find is the better a filter filters, the more resistance it has to airflow. so it helps to have a bigger surface areaAre those finer filter tingos you mentioned for the inside of the filter?? and can you post a pic of it?? if you can, and can supply some vital measurements i can probably design and make a high eficiency filter no probs,, i make filters for surgical units and bio labs among other types of filters.
PostPosted: Fri Mar 04, 2005 10:44 pm
I dont have a boxed Piper Cross or K&N with me but do have a RamFlo 400 for a Dellorto 40/45/48 with no ratings on it and I can not say I have seen any before :?
Can you explain what you make your Surgical Units outof, Could be interesting..Also can you clean them and...re-oil them :?:
PostPosted: Fri Mar 04, 2005 11:09 pm
actually most surgical units and bio tech labs use heppa filters which would be overkill in a car.. i dont suppose microbes are a hassle for a carbs and the petrol probably stuffs them anyway.. but we use some amazingly efficient filter medias for a variety of aplications that may well suit different motoring uses. If the doc can post a pic of the fine filter more than likely we would have something as good if not better.
PostPosted: Fri Mar 04, 2005 11:14 pm
I have to Clean out Morris filter tomorrow so I'll take a pic for you of the Piper and cross, and the Ram flow....I thinking what you use would be similar to the mask you get at hardwares...but with a little more work involved....
I'm not being smart or anything , just similar looking. Guessing
PostPosted: Fri Mar 04, 2005 11:24 pm
yeah we have allsorts and some looks like that stuff we also make the final filters that protect the vaccuum units on the road and curb sweepers.. actuallty at the moment im also working on a low cost home spray booth tent that you can hang in your garage.. sure beats cleaning the garage out if your garage looks anything like mine does now LOL..
PostPosted: Fri Mar 04, 2005 11:35 pm
Thats a long way from the medical side, Interesting..I'll get some pic's off to you tomorrow :wink:
PostPosted: Fri Mar 04, 2005 11:42 pm
thanks gafmo and sorry runtie hope you enjoy that detour, LOL the post is yours again
PostPosted: Sat Mar 05, 2005 6:16 am
`Finer filter' is just a flat oval foam pad that replaces the stock moulded Ramflo foam. It is a bit more open so less restriction. Relies on being wetted with Finer Filter oil for filtration.
It works- you should see the crap I wring out of it when I wash it every 5000 miles or so. :wink:
You wash it with turps or detergent, then dry it and re-oil.
Finer Filter got bought out by Unifilter a few years back. If anyone is interested in these pads, contact Unifilter- I'm sure they would cut you some specials. It's only flat foam. 8)
Finer Filter oil is now NLA too- the Unifilter oil is much the same.
