It is currently Thu Jun 26, 2025 10:26 pm
Post new topic Reply to topic  [ 20 posts ]  Go to page Previous  1, 2
PostPosted: Fri Mar 04, 2005 1:46 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
that sucks the bitch and charlie both have remotes if i do a reco on the new toy it will get a remote aswell
makka
PostPosted: Fri Mar 04, 2005 1:51 pm
I don't mind the rod change boxes, except for the lack of engine stabilisation. But if I were to rebuild a box, I'd rebuild the original remote box from the motor, that's what it's meant to have. Rod box went in because the remote box was completely stuffed...
PostPosted: Fri Mar 04, 2005 1:58 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
yeah i would have pulled the guts outa the rod box and sunk them into the remote same fit ask the good doctor
makka
PostPosted: Fri Mar 04, 2005 2:13 pm
yeah i know, but I wasn't up for a gearbox rebuild at the time, was more interested in just having a car. Why is it that I am forced to continually take the easy option to fix my car simply so I can be mobile ??
PostPosted: Fri Mar 04, 2005 2:47 pm
Anto wrote:
Flashback wrote:
Try this link from Minimani in the states. Probably more useful for ones that haven't broken yet but worth a look anyway
http://dealer.minimania.com/web/Item/MSSK1500/AddedFrom/CatBrowse%2D%20ENGINE%5FSTABLIZ/InvDetail.cfm
That kit looks like the gear I need. However, it is not available locally and I think ordering it from O/S would take too long. At this point in time I think I will get another lower bracket off a parts car, and put a couple of bolts through to hold in on with some big flat washers to spread the load. Will probably be better than the original spot welds :)
I will also look in to adding some lower engine stabiliser bars. They are a bit costly but I may have to bite the bullet if I want to avoid this problem in the future.
Anto.
Anto, I would just clean it all up and take it to someone who is real handy with a MIG. Find a good muffler shop... :wink:
