It is currently Sun Aug 24, 2025 12:01 am
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 28, 29, 30, 31, 32, 33, 34 ... 568  Next
PostPosted: Sun May 24, 2009 6:11 pm
Chucked it up on stands ready for the big cut n shut
PostPosted: Sun May 24, 2009 6:15 pm
The wife started putting the new carpets in and I gave it a bit of a tune, she will finish the carpets next weekend
PostPosted: Sun May 24, 2009 6:22 pm
Fitted the engine mount/lower radiator support - fitted new thermostat then the radiator only to find the top radiator hose suppled by Karcraft is about 1" too short :evil:
Fiddled with a couple of short brake lines for the rear wheels and salvaged some old female fittings as the new ones I bought are short about 2½ turns hence stripping threads :evil:
Fitted a brake line from the firewall T piece to the subframe/brake switch T piece.
Had a look at my dripping sump plug.
David L
PostPosted: Sun May 24, 2009 6:27 pm
put the engine back in after taking it out yesterday, swapped the steering rack for a new less buggered one, put it all back together and drove her round the block. Then put her in dads shop and went home has to get a wheel alignment and such tommorow
I'm grew up on the street, not the hood, the sesame st
PostPosted: Sun May 24, 2009 6:45 pm
Didn't like the idea of the steering wheel moving up and down and my indicators not cancelling. Loosened the U-bolt and swung it around to line up the indicators. Had a hard time getting the shaft all the way down. Finally got it sorted and for once I have indicators that self cancel. Unfortuantely now my steering wheel is not facing the right way. Need to find a socket for the boss, that will be next weekends job.
 Post subject: Today I...
removed my subframes and stipped the rear. Now its time to clean up (about 5kg of grime and dirt) and repaint put it back together and wait for the rest of the car!
It's not the size of the dog in the fight, but the size of the fight in the dog!!
1976 Mini SS
1971 Mini Ute (Custom) - really hubby's but I will claim half :)
1976 Mini SS Shell
Oh and an 850 shell waiting for our dear son to start his resto!
PostPosted: Sun May 24, 2009 6:48 pm
cooper19613 wrote:
Gave it a wash and took it to a car show at Medowie.
Bugger, I forgot about that :(
Dicko
PostPosted: Sun May 24, 2009 6:52 pm
Today i decided to tidy up an existing grill i had, was a run through for when i do my other grill.....
What you think!?!
PostPosted: Sun May 24, 2009 9:27 pm
Tomboss Breweros
gafmo wrote:
Tombo you need a little Australian flag after it just like race car drivers :lol:
Hmmm, i like :wink:
kimini wrote:
Jimmyinamini wrote:
PostPosted: Sun May 24, 2009 9:29 pm
Tomboss Breweros
gareth-in-adelaide wrote:
Too much toe out :roll: :lol: :lol: :lol:
kimini wrote:
Jimmyinamini wrote:
PostPosted: Sun May 24, 2009 9:56 pm
won my local motorkhana 8)
what's not to be sure of with that paint finish Tom???
PostPosted: Mon May 25, 2009 5:20 pm
The TIG
Cut the front off of a Mini that somebody offered me so I can put it on one of the Minis I picked up a couple months ago. Cut some rust out of an old rear subframe and welded in some fresh steel and give it a paint job. Clean up the points in an old voltage regulator and set it all up according to the specs in a FSM.
email - [email protected]
www.victoria-chiropractors.ca
PostPosted: Mon May 25, 2009 6:46 pm
On Sat I put 1lt of oil in the LS and then drove it 115 miles to cut the back of a mini, then put it on my trailer and towed it to its new home. Sunday I drove another mini around some bends { at speed} and today iI found the left rear top suspension arm in the Fang is bent by about 1 inch
PostPosted: Mon May 25, 2009 7:22 pm
removed the front bumper of my moke and knocked it back into shape then gave it a quick coat of paint before i put it back on again
Idrilled a couply of holes so I can start hiding the Loom.
Then I got sick and tired of catching my knees and backside on the seat rails and suport some one had put in :roll:
Rails were easy enought to rip out but who ever welded the suports in didn't want them to come out again
after two 1/2 hour of cutting with my trust grinder they were finaly out but the leftover welds were still thier so the trusty grinder was worth its weight in gold today
Linished to complett and only one hole on the tunnel just behild the handbrake which will have to be welded up aswell with the Majic Wand hole also
I love using my grinder specaily when I am happy with the result
