It is currently Thu Jun 26, 2025 1:15 pm
Post new topic Reply to topic  [ 248 posts ]  Go to page Previous  1 ... 12, 13, 14, 15, 16, 17  Next
PostPosted: Thu May 21, 2009 1:12 pm
Hey Pubs - I would REALLY like to see/hear details how you integrated the Starlet wiper motor with the Mini... please? :(
-Alan
PostPosted: Thu May 21, 2009 2:07 pm
nice man, those wheels look class - i like your old ones as well. pity about your grill though, im not a fan sorry.
PostPosted: Thu May 21, 2009 7:09 pm
pubudug wrote:
I know a few of you have been using the KKR turbo with good results. Its either a TD04L or a KKR280 (is some other TD?? off a forrester which meant to be smaller)?
Thanks in advance guys
Cheers :twisted:
Looks good man.
I'm actually waiting for the DPI to send my mod approval to my correct address ( :roll: ) then I should have it over the pits in the next few weeks. It must be such a feeling of acomplishment to have it registered! ....I can't wait.
I actually have a Forester turbo in my shed. The designation is TD035.
Looks like a good step up from the CT9, but not too big.
Has any one done any reasearch into the CT12 off the Toyota 1Js and 2Js? Do they use the same flanges as the CT9s?
-James.
Toyota 4EFTE Powered Minivan.
PostPosted: Thu May 21, 2009 8:31 pm
Lookin good Pub's I will have to come and have a look at some stage when I get a chance.
The CT12 uses a totally different flange so are no good, may be able to make up a bit of a hybrid though of the two
I would probably go the KKR280 route T2 flange, cheap and known to work well.
4efte powered Clubman
supercharged 998 race car
PostPosted: Thu May 21, 2009 10:18 pm
hi guys,
just thought I'd upload a pic of the whole car with the new wheels etc.. I bought some sportspac arches to fix on since the new wheels stick out too much!.. I don't want to get pulled over by the boys in blue.
My thoughts exactly.. if the turbo screws up.. buy another one! :D
My boost controller isn;t working properly.. takes a LONG time to build boost.. surely it can't be the wheels! :(
Give us a call any time Ben, I hope you have my number from before. I work 2 weeks on 2 weeks off though...
PostPosted: Fri May 22, 2009 10:30 am
That's easy to test. Block the line/hose leading to the wastegate and see how quickly the boost climbs without the controller attached (By saying this, I assume you have a boost gauge to monitor boost levels) Just be really careful that you don't build too much boost and back off at a safe point (your normal max boost) as the wastegate won't open at all with this configuration.
-Alan
PostPosted: Fri May 22, 2009 3:23 pm
I Love those wheels. Tyres look hot too! :wink:
-James.
PostPosted: Fri May 22, 2009 9:48 pm
There's nothin quite like a little free boosting! :D
Life's a garden.... Dig It!
PostPosted: Fri May 22, 2009 11:29 pm
Just curious....where are your indicators and parkers :?:
PostPosted: Sat May 23, 2009 12:49 am
The parkers are contained within the main globe (They look like the H4 halogen replacement headlights) and the indicators are probably the square clear ones at the bottom of the main grill.
-Alan
PostPosted: Sat May 23, 2009 11:50 am
I doubt those blinkers would be legal here in NSW, they are too far in from each side.
I like the intercooler plumbing there though! :lol:
edit> I said parkers by mistake, lol
Last edited by drmini in aust on Mon May 25, 2009 7:17 am, edited 1 time in total.
PostPosted: Sat May 23, 2009 4:08 pm
Hey Pubs,
Was wondering what did you do with the speedo?
Did you simply just plug it in? If so it would over read (Ie. read a higher speed than the actual speed). Did you make a gearbox or something or was the difference so insignificant?
Reason I ask is that I'd like to use the Starlet cluster as moving to electronic guages can be very pricey, and the Starlet cluster is free.
PostPosted: Sat May 23, 2009 4:20 pm
Spot on. I had no issues with the parkers or the indicators from the Regency boys..
My boost controller is officially stuffed. NOT HAPPY! The solenoid works fine but the actual IBC doesn't give enough signal to drive the solenoid. it just makes a buzzing noise. I have emailed Gizzmo. We'll see what they say :evil:
Thats a long story :D I found another toyota dash which has an electronic speedo and transferred all the bits behind the face plate into the starlet dash. The odometer and trip meter matched up with their holes pretty well so I'm happy. Its a simple 3 wire installation ( +12v, ground & signal)
I then went to the wreckers and got a electronic speed pick-up unit for the gearbox. ( just took in the mechanical one and matched it up - cost me $30)
I then got a speedo corrector unit from Jaycar and tuned it with the aid of a GPS unit..
She works without any issues.
so yeah.. a bit of work if you want to do it right. Connecting the cable is not too good.. readings will obviously be out
PostPosted: Sun May 24, 2009 11:34 pm
I'm Ernie , Where's Bert ?
thats lookin sweet mate...congrats on gettin her road-bound :D
00' Forester GT
PostPosted: Mon May 25, 2009 10:37 am
Anyone doing a 4EFTE conversion and wanting to retain the standard Starlet dash/instrument cluster (has a mechanical speedo cable just like the Mini) you simply need to take it to an instrument workshop to get it recalibrated. For big changes like Starlet => Mini wheels, you can install a mechanical ratio box between the gearbox & dash. Last time I looked, these boxes are at least $150.
-Alan
