It is currently Fri Aug 22, 2025 6:29 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 9, 10, 11, 12, 13, 14, 15 ... 568  Next
PostPosted: Fri May 01, 2009 9:01 am
I took the 850 to James at Wilson Automotive in glenorchy. He fixed my leaking fuel tank, replaced my stuffed brake light switch and fixed my sticking accelarator cable. The man is a mini god! not trying to suck up but I am rapt with what he did to my car and his customer service is awesome! highly reccomended for any mini troubles in tassy :D
88 Rover 1.3i "Reggie"
99 Rover 1.3i “Grover”
17 Mini Clubman JCW “Noddy”
PostPosted: Fri May 01, 2009 9:46 am
Milatsmadmini
got some worn 008's to go on some widened steelies for some fast runs.... hehehe
finished grinding out my intake manifold and matched it with the new head ill be putting on, reduced the thickness of the flange so it sits flush with the extractors...
replaced top steady bushes with some nice urethene mini sports products... tie rod bushes are next....
waiting for Karcraft to call me to say pick up the hi flow pump so i can grind out the block if need be...
got my radiator back from charlie out in blacktown, top bloke, great work and still $90 hehehe
trying to put everything together very quickly so i can get the moke over to the sailmakers to get a cover put on it.... woooooooo!
bumped into grieg malure.... who just laughed at me when he saw me... (how the hell do these people find out about wheels falling off!!! its just bizzare!! damn small mini world!!!)
PostPosted: Fri May 01, 2009 5:22 pm
installed the H4s ive had sitting in the garage for a few weeks.
PostPosted: Fri May 01, 2009 5:35 pm
This space for rent
Did you put them on relays? Do it, the difference in lighting is unbelievable :shock:
PostPosted: Fri May 01, 2009 5:47 pm
Put in a 88 degree thermostat. The engine was running too cool with a low temp thermostat.
 Post subject: On My Mini today...
PostPosted: Fri May 01, 2009 6:01 pm
Today I fitted a long range Fuel tank and an eye level stop light and I also fitted a switch to override the Thermo fan switch manually. Fitting this tank will save me fitting the RH tank which I will be fitting to My Mini K instead, when I do it.
"Let us remove your "SHORTS"
Last edited by Convertible Mini on Fri May 01, 2009 6:02 pm, edited 1 time in total.
PostPosted: Fri May 01, 2009 6:02 pm
The TIG
The last couple evenings I've worked on the cage in the Travelle"R". I have built the last of the tubes and welded all of them in except the door tubes. I'm currently mounting the seats where I want them and then I'll fine tune the door bars and weld them in. I've also done some more welding on the car and I've been organizing my huge pile of Mini parts.
email - [email protected]
www.victoria-chiropractors.ca
PostPosted: Fri May 01, 2009 6:29 pm
yeah put onto a relay at the same time so cant really tell which made the most difference.
PostPosted: Fri May 01, 2009 8:09 pm
This space for rent
Well I'm having a night off Mini's tonight.. might play some poker instead.
Tomorrow I might install the shiny new indicator arm in the van which arrived today, thanks Tony ;)
PostPosted: Fri May 01, 2009 8:18 pm
I gave the van a good clean inside and out then took it to get some photos taken by the local newspaper for their auto section.
Now it's sitting in the shed waiting for me to find where all the bloody oil is leaking from, why the radio now goes static when the engine is running and why high beam has gone AWOL :evil:
Image Image
PostPosted: Fri May 01, 2009 8:24 pm
Replaced a broken accelerator cable on one of the fleet, which had unfortunately broken in peak hour traffic at the top of Oxford St.
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Fri May 01, 2009 8:41 pm
I reckon this thread has the potential to be the loooooonnnngggest running in the history of ausmini ....
In the words of Ali G, "let's make it appen" Foreal.
PostPosted: Fri May 01, 2009 9:02 pm
This space for rent
When all other threads have withered and died, we'll still be fixing sh!t on our Mini's so this thread will be alive and well ;)
PostPosted: Fri May 01, 2009 10:56 pm
I hope you didn't jump out, open the bonnet and bend over the engine.... :shock:
last night I did the wheel alignment, put some more fluid in the hydro and changed the oil
tonight I adjusted my back brakes, and replaced the left rear wheel bearing
ready for tomorrow, so now I'm off to bed :)
PostPosted: Sat May 02, 2009 7:13 am
More blinging but least im onto the 240grit with 400 to go and polishing on the GR Manifold
Users browsing this forum: No registered users and 318 guests
