It is currently Fri Aug 22, 2025 6:32 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 8, 9, 10, 11, 12, 13, 14 ... 568  Next
PostPosted: Thu Apr 30, 2009 12:47 pm
ginger ninja
ginger ninja
absolutely nothing :) because my little car is perfect and doesn't need anything done
edit: who edited my post :P
sports850 wrote:
PostPosted: Thu Apr 30, 2009 12:57 pm
This space for rent
simon k wrote:
awdmoke and I have the same thing happening, higher pressure at idle than at revs - I was gonna try a bigger ball. Let me know what works ;)
I reckon that's normal -- at idle, there's not a lot of oil flow so the ball closes the valve completely and the pressure is higher. At revs, greater flow pushes the ball off the seat and the pressure drops. The old valve would have bound against the bore wall and masked all of this.
It's the flutter I don't like... where it ends up (50psi hot) is fine. I'll whack a couple of flat washers in behind the nut and see if that helps.
simon k wrote:
maybe have *another* go at wheel alignment
Do it by eye, it's easy and pretty accurate ;) With the steering centred, stand a couple of metres in front of the car and put an eyeball on the vector which touches the leading and trailing edges of the tyre sidewall. If your toe-out is spot on, this line should touch the leading sidewall of the rear tyre. Do both sides and you're pretty close to perfect. This assumes of course your rears are where they should be ;)
I used this procedure on my car in October '07, have done about 7000km since with no undue tyre wear. We did Mick's too after pumping up the hydro, and it turned out to be about a quarter-turn of the tie rod end out.
PostPosted: Thu Apr 30, 2009 1:56 pm
Tomboss Breweros
I use that method and get better tyre wear than if it's done on a machine.
I'm going to re size my door trims so they fit easier tonight, and line the doorbins.
kimini wrote:
Jimmyinamini wrote:
 Post subject: 88 Rover Cooper Toy
PostPosted: Thu Apr 30, 2009 2:27 pm
Rover Cooper
I polished the dip stick, and checked the tyre pressures for the drive on Saturday, may even polish the rear subframe for something extra to do.
PostPosted: Thu Apr 30, 2009 4:00 pm
I turned the parkers on whilst driving, this let some of the Lucas smoke out from under the dash :shock: so I turned them back off... :lol:
Diagnosis and treatment tomoz, but I've pulled the thermally challenged red wire off the switch for now. To be sure, to be sure....
PostPosted: Thu Apr 30, 2009 8:00 pm
bit more bling on the manifold :roll:
PostPosted: Thu Apr 30, 2009 8:48 pm
Stuff arrived from MiniKing and the Doc today - might just go downstairs now and "fiddle" for a bit :wink:
David L
PostPosted: Thu Apr 30, 2009 8:56 pm
I'm Ernie , Where's Bert ?
swore at it when it was still running like a pig
then contemplated hurling a brick at it... :evil:
00' Forester GT
PostPosted: Thu Apr 30, 2009 9:15 pm
ooh i want my stuff from miniking :( should be here tomorro :)
'94 Honda EG4 Civic. -Daily-
'95 Honda DC2 Integra
PostPosted: Thu Apr 30, 2009 9:36 pm
Went to work this week so I can spend more money on it next week. :?
Dave K.
PostPosted: Thu Apr 30, 2009 10:17 pm
Removed the passenger side front guard from the 1275LS Project..
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Thu Apr 30, 2009 11:14 pm
This space for rent
Fiddled some more with the oil pressure relief valve and have it where I'm pretty happy with it. First tried a thick (4mm or so) washer behind the nut to eliminate the flutter as revs rise, but pressure gave 100psi a scare (cold) on the first drive around the block. I figure too much of a good thing isn't a good thing.
So, out with that one and in with one about 1.8mm. Pressure is now:
Cold - about 80psi anywhere in the rev range
Hot - 45psi btw idle-1500rpm, 75psi btw 1500-2500rpm, then 60psi above that.
Still have a little pressure flutter just off idle, but I can live with it now.
Gave it a fang on the freeway and back roads for an hour or so, cruising at around 4400rpm to get it nice and hot. Boy, is the pressure stable now 8)
PostPosted: Thu Apr 30, 2009 11:36 pm
Tomboss Breweros
swae85 wrote:
absolutely nothing :) because my little car is perfect and doesn't need anything done.
One in a million, i wish my minis could reach that status :wink: :wink:
kimini wrote:
Jimmyinamini wrote:
PostPosted: Thu Apr 30, 2009 11:38 pm
Filled her up with petrol and drove to shops.
1967 Mini Deluxe 1275 heaps of modifications
1969 Mini Matic 1100
PostPosted: Fri May 01, 2009 8:23 am
ginger ninja
ginger ninja
bahahaha I never wrote that! Someone edited me :P My car needs stacks done but will have to wait a while
Users browsing this forum: No registered users and 285 guests
