It is currently Wed Jul 02, 2025 11:49 pm
Post new topic Reply to topic  [ 120 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6 ... 8  Next
PostPosted: Wed Feb 23, 2005 3:03 pm
m.
my monster is a bit of a pain in the arse at times.
dash looks tops,looks better than most,still dont no what im gunna do with mine yet :cry:
BRICKWORX RACING
872-874 South Rd
Edwardstown
SA 5039
PH: 8297 9494
FAX: 8297 7133
PostPosted: Thu Feb 24, 2005 8:19 pm
Talking dashes... if you dont want to go to the effort of custom making a modern day dash (even though that thing looks WICKED) and have a basic roundnose... is it possible to fit a clubman dash..? I dont necessarily want the clubman dials and stuff, what I want it the top part and bottom part of the dash (you know that high tech hard rubber/plastic thing in black that cracks after 100 years in the sun) and then to custom my own wood front to put my dials and stuff, with the speedo still in the centre. I was told the Clubman stuff fits, but before I go looking for one....
:D
PostPosted: Thu Feb 24, 2005 8:33 pm
yeah the rail on a roundie is the same as on a clubie if you look under the rail, i would make you dash, its really easy if you measure it out and do it properly, my dash is made of mdf and is just covered with a carbon fibre look sheet, u can get the stuff from auto barn for cheap, mines come up real nice!
i put a top rail on (as u can see in the pic) and it finishes it off well, u only have to modify the top rail to house the mk1 heater holes as they are in a different position, real easy though! :wink:
Potato
PostPosted: Thu Feb 24, 2005 8:45 pm
alternatively, you could make a top dash rail as I had done for bricktop...
it really blends the top of the dash and facia well.....
68matic: "i havent seen much head in my life "
PostPosted: Thu Feb 24, 2005 9:02 pm
got better pic;s of your dash duke nuke?
im doing that to my dash ATm and would look a good pic of it :D
BRICKWORX RACING
872-874 South Rd
Edwardstown
SA 5039
PH: 8297 9494
FAX: 8297 7133
PostPosted: Thu Feb 24, 2005 9:05 pm
give me 10 mins and they will be here
<insert photo>
PostPosted: Thu Feb 24, 2005 9:08 pm
hmmm does that mean that you are selling your current dash..??
:wink:
PostPosted: Thu Feb 24, 2005 9:22 pm
i dont have a dash ATM,its just a autometer monster tacho and oil pressure gauge on the A pillar...they will stay bit other stuff like water temp,volts,oil temp,BOOST :lol: (for the vacume :P )
BRICKWORX RACING
872-874 South Rd
Edwardstown
SA 5039
PH: 8297 9494
FAX: 8297 7133
PostPosted: Thu Feb 24, 2005 9:25 pm
as you can tell,i LOVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVE my gauges :P
BRICKWORX RACING
872-874 South Rd
Edwardstown
SA 5039
PH: 8297 9494
FAX: 8297 7133
PostPosted: Thu Feb 24, 2005 9:32 pm
heres the pic....
PostPosted: Thu Feb 24, 2005 9:34 pm
That dash looks wild.
Many rattles?
Did you do the brush effect with a sanding disc on a drill press?
ohhhhhhhhhhhhhh thats honey,thanks duke
BRICKWORX RACING
872-874 South Rd
Edwardstown
SA 5039
PH: 8297 9494
FAX: 8297 7133
PostPosted: Thu Feb 24, 2005 9:37 pm
how hard is it to get in and out?
how did you go at rego time with a re-flective dash?
BRICKWORX RACING
872-874 South Rd
Edwardstown
SA 5039
PH: 8297 9494
FAX: 8297 7133
PostPosted: Thu Feb 24, 2005 9:45 pm
as you ca see, I love my guages too! Soon to have boost added and a new tacho with shift light..... then I will have 8 guages plus speedo 8)
PostPosted: Thu Feb 24, 2005 9:48 pm
3 screw hold it firmly in place... i had it checked by a cop a couple of onths back and he said it was fine....
it isnt that reflective as the mini windscreen is pretty vertical... Never had a blinding bit of light in 4 months...
I did the brushed effect with an orbital sander, just a hand held one...
it is pretty sweet i think... i have only heard one negative comment about it
