It is currently Sat Jun 28, 2025 7:33 pm
Post new topic Reply to topic  [ 35 posts ]  Go to page 1, 2, 3  Next
 Post subject: Spark plugs
PostPosted: Tue Feb 22, 2005 4:16 pm
Hey
What plugs do you use?what plugs do you stay away from?what gaps do you use? :D
i myself use champion N9YC's in mine,i think they are a good all around plug :D
what do YOU use?
BRICKWORX RACING
872-874 South Rd
Edwardstown
SA 5039
PH: 8297 9494
FAX: 8297 7133
PostPosted: Tue Feb 22, 2005 4:23 pm
I think with the Pulsar Dizzy Kev said you could run 0.9 plug gaps :?: can't remeber any mention of brands though
Roads need more corners
PostPosted: Tue Feb 22, 2005 7:37 pm
N9YC's here.
25 thou gap too.
Its what the king recommends. :)
PostPosted: Tue Feb 22, 2005 9:13 pm
Bosch W6DCs, 0.9mm gap with Pulsar dizzy & coil.
At Wakefield Pk I run NGK BP7ES, don't use them on the road any more after a couple went belly up while cruising..
This motor's running 10.4:1 C/R, though- for stockies I'd run Bosch W7DC or NGK BP6ES or Champion N9YC. :wink:
PostPosted: Tue Mar 01, 2005 9:12 pm
i was running N9YC's, but i've got a bit of an oil problem so i got some hotter plugs, champion gold's. 0.025 gap
78 Leyland Mini - Prince
PostPosted: Tue Mar 01, 2005 9:18 pm
hopefully with my datsun dizzy ill be running bigger plug gaps,im at 0.025 too,hopefully ill goto 0.040 :D
BRICKWORX RACING
872-874 South Rd
Edwardstown
SA 5039
PH: 8297 9494
FAX: 8297 7133
PostPosted: Wed Mar 02, 2005 2:09 pm
Ihave always sworn by NGK plugs but now i think they have gone CR*P, so i moved from a BP6ES to a W6DC as the Doc mentioned and i have not had a fouling problem since, i also have some champions to try out soon enough too, i have just purchased a two sets of new NGK race plugs made in Japan so the Quality is better than the normal NGK from Tiawan or where ever, B9EGV and B8EGV these are race plugs and maybe a litttle cold for my motor but i will give them ago and report.
100% Pure A Series Turbo
PostPosted: Wed Mar 02, 2005 2:45 pm
I use NGK Irridiums in both Morris and the Alfa 75 (Angelo)
Have not had a problem yet
PostPosted: Thu Mar 10, 2005 3:13 pm
well i have only driven the car a few times and not in much traffic etc, but so far the B8EGV race plugs seem to be up to the job.
once the clutch is sorted i will have a better drive and advise results.
PostPosted: Thu Mar 10, 2005 7:17 pm
What the difference between N9YC's and RN9YC's except the cost?
And are the RN9YC's any good?
Pete
PostPosted: Thu Mar 10, 2005 7:37 pm
RN9YCs are a resistor plug, made for late model cars with electronic ignition. If you have stock ignition and suppression leads, don't use them as it will reduce spark intensity.
OK to use if you have real wire leads and no suppression caps on `em. :wink:
PostPosted: Thu Mar 10, 2005 10:23 pm
If I'm running a Pulsar dizzy should I run these plugs or just go for the standard ones?
Pete
PostPosted: Fri Mar 11, 2005 6:38 am
Pete
I would go for standard ones. For a stock motor,
Champion N9YC,
Bosch W7DC,
NGK BP6ES.
Gap 'em all at .035"- I found a slight misfire when cold at .040".
Make sure your plug leads are good. I like the Bosch ones better than Top Guns- $5 each at Supercheap. :wink:
PostPosted: Fri Mar 11, 2005 7:26 am
Thanks for that.
Pete
PostPosted: Sat Mar 12, 2005 10:59 am
Who has tryed and tested split fire spark plugs?where apparently the spark is more exposed again...and putting the spark plugs in all the same way?is it realy worth power?
BRICKWORX RACING
872-874 South Rd
Edwardstown
SA 5039
PH: 8297 9494
FAX: 8297 7133
