It is currently Fri Jun 27, 2025 2:58 am
PostPosted: Sun Nov 09, 2008 12:01 pm
Hey guys,
another question re my engine build
I am building another small bore, and I wish to stay under 1200cc.
Its a shame the use of Hillman Imp pistons takes it to 1215cc.
What pistons can I use (mini or non mini) to achieve the maximum cc, but staying under 1200cc.
My block is sitting here waiting to go in to get bored/honed, just need to know what to.
PostPosted: Sun Nov 09, 2008 2:05 pm
The Forkmeister
I thing GR has 100 thou plus pistons for sale, but I have been know to be wrong. :D
May the fork be with you.
PostPosted: Sun Nov 09, 2008 2:33 pm
Give Ash some flowers Nick .
Based on a quick calculation +0.100" should take a 1098 to 1185cc's. :wink:
<edit> I also recall GR having +0.100" pistons for 1098's
PostPosted: Sun Nov 09, 2008 2:35 pm
Yep he does but unsure if he has stock? best to call
PostPosted: Sun Nov 09, 2008 4:18 pm
+0.100 flat to pistons from GR in my 1098 block
Just had them done - he should still have them in stock - give him a call
David L
PostPosted: Sun Nov 09, 2008 5:01 pm
Is it me or has that block got too many holes in the top?
PostPosted: Sun Nov 09, 2008 5:19 pm
pure porn. thanks guys. before I call him, how much are they going to set me back? do they come with rings? who makes them?
PostPosted: Sun Nov 09, 2008 5:32 pm
I'm sure they come with rings in the price but as to what that is I don't know - they were included in the total price of the assembly. Best ask him. GR has them made to his specs in Tiawan. I had to wait nearly 2 years for them as his first shipment went 'missing' and as by world scale his order was a small one they put the re-run to the bottom of the pile :cry:
David L
PostPosted: Sun Nov 09, 2008 5:39 pm
Ah thats no good at all. was hoping to get the motor together for next years meets. Ill give him a call and find out. thanks mate.
what compression are you running?
PostPosted: Sun Nov 09, 2008 5:41 pm
I think they are around $275 a set. GR pistons are made in Taiwan, (Hypatecs are too). These come with a Nippon ringset, they are good. Better than Hastings. :wink:
I'm sure he has them in stock - as part of the order went to MS in the UK and needs them for his own stock as well.
Haven't worked out compression yet - running 295 head hence the flat tops.
David L
PostPosted: Sun Nov 09, 2008 5:47 pm
cheap. ill ring tomorrow to order my set.
thanks, once again for everyone's comments.
I was planning on using a 940 head, would the flat tops still work with the modifications to the block?
PostPosted: Sun Nov 09, 2008 9:31 pm
Yes.
But your C/R will be pretty high unless you enlarge the chambers heaps, stock they are only 21.4cc.
PostPosted: Sun Nov 09, 2008 9:42 pm
hey doc.
thats fine, I was after a high c/r, and the head will be quite modified.
Ill keep you all posted.
PostPosted: Mon Nov 10, 2008 9:19 am
he said I shouldnt be running a 940 head. stick to the 202 instead.
He has a lot in stock, so when I get back from my travels ill get the missus to get me some for Christmas.
