It is currently Fri Jun 27, 2025 2:10 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 42 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Wed Aug 20, 2008 10:31 am
So Matt, when are you going to make a conversion kit to run one of Bens SC kits with the 16V heads?
PostPosted: Wed Aug 20, 2008 10:40 am
Does the kit include the head, or would we need to source that elsewhere?
Any idea on the probable cost?
PostPosted: Wed Aug 20, 2008 11:18 pm
Checkmate wrote:
How hard will these kits be to fit??
Could a noob like me do it??
Don't take my word for it but I think you should know your way around an engine before attempting this... But don't let me put you off, the best way to learn to swim is to be pushed in the deep end.
PostPosted: Thu Aug 21, 2008 12:22 am
Forum Graffiti
There's a fair amount of machining work to be done on the block ( plugging up holes, re-drilling the new head stud pattern, etc ) which the machine shop would be able to help with. Not sure if you have to stuff around with bore centers...?
And then there's getting the head on and all the belt drives, jack shafts and stuff setup.
I'm sure Matt will give you the run down :)
PostPosted: Thu Aug 21, 2008 12:30 pm
1275 blocks don`t need stuffing with regards to bore centres, but the small bore blocks do
plugging up the old holes in the top of the block & re-drilling for the Bimmer pattern is easy,,, then just a quick skim the block nice & flat & you`re away
bolt it all together & plumb up your carbs or injection & bolt on the extractors or turbo manifold, whatever you want to do is totally up to you
You just have to decide 8v or 16v ,,,, Naturally asspirated or turbo,,,, before you build the donk
simple really,,, same as building any engine
ring me or PM me for a price &/or any other details after tomorrow please
Matt
PostPosted: Fri Aug 22, 2008 8:16 pm
This is what you get--->
1x alloy front head plate 2 suit 8v or 16v (your choice)
1x alloy lower flange piece to suit that front head plate.
2x alloy upper pulley bosses,
2x cam pulleys, 2x sandwich plates for those pulleys,
6x bolts to secure the sandwich plates to the pulley bosses
& 2x bolts 2 secure the pulley assys to the Bimmer cams,
plus 2x oil seals.
1x alloy front engine plate,
1x steel mini cam pulley boss & 1x mini cam pulley, 3x bolts for same,
1x crank pulley,
1x steel crank pulley spacer,
2x oil seals,
1x timing belt & 1x timing belt tensioner
& a bag of bolts & screws to secure the 2 plates to your engine.
You also get a pair of alloy fitting plugs, to allow you to set up the front cyl head plate dead central so you can dowel it to the cyl head for no oil leaks.
there was a pic up on another thread recently of all the bits but telstra in their wisdom have stuffed up somehow tonight & i can`t access it for some reason,,, so i`ll sort that in the next day or so & get a pic of all the bits up here too
I have some 2nd hand 8v cyl heads here for sale
& i have some N/A extractors made ready to go & also have some turbo manifolds & dump pipes made & ready to go too.
Ring me or PM me for prices & other details please,,, sorry but there`s just way too much to go into differnet engine combos & arrangments & assortments here.
I`ll have a pic of the whole kit up here shortly
Edit--> some kits allready sold,,, got to be quick or they`ll all be gone.
PostPosted: Mon Aug 25, 2008 4:28 pm
it'll mean if you have a sticker on your mini saying "genuin mini, no BMW parts" you'll have to take it off. :lol:
PostPosted: Fri Aug 29, 2008 10:51 pm
ok ok ,,, you got me there Andrew
see you at the muster,with your BMW-less mini :-)
PostPosted: Thu Sep 11, 2008 11:48 am
Twinky Cyl head conversion kits are up on e-bay starting at lower than my own cost
http://cgi.ebay.com.au/Mini-Twin-Cam-Conversion-Kit_W0QQitemZ170260650611QQihZ007QQcategoryZ33612QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
there is a whole pile of these engines being produced all around the world now
These guys are doing their own dyno shoot-out next february in Englan-->
http://www.efiminis.olicentral.com/index.php?topic=204.msg2439#msg2439
& there is a bundle more of them happening in the States now too
A Build guide is going onto CDs & will be sent free of charge to the purchasers of my fitting kits at a later date (once it`s finished, probly be a month or 2)
I am sending a bottom rad hose "S" pipe to adapt the bottom radiator hose to clear the timing belt & also giving a braket for the L/H engine steady bar to bolt to the front cyl head plate to the first few kits sold,,,
I`m allready making up a pile of oil feed hoses to the cyl head (for those of you who don`t want to groove your front cam bearing & re-drill the cyl head oil feed hole to line up with the one in the mini block) so these will be avaliable shortly.
As you should allready know,,, i have jigged up & made both N/A extractors & turbo manifolds with dump pipes to fit under the bonnet & they are avaliable right now
& i am in the process of making alloy inlet plenum chambers to suit both siingle throttle bodies & carby flanges (most probably suit 1&3/4 carb , so an 1&1/2 carb will obviously also fit if you so desire) This will be a fairly cheap way to run a carby & dizzy for those who havn`t got the cash to set up Engine managment systems straight away, so should be able to bung the SU carb on, stick your old dizzy in the hole, swap 2 ign leads around, start the car & drive away-ish
If my wiring man (Jonno) got off his arse then we`d allready have a pile of wiring looms sitting here to suit the Adaptronic computer, & very soon we should have a start up program sorted to simply dump into the computer to get you going should you decide to go the std Bimmer quad throttle body injection route.
I`m also developing a crank & cam angle sensor package (not the one inside the dissy like what is on the moke atm, but seperate external type ones with brakets & pulley to simply bolt to your engine & plug the loom into them... & of course dump the program into the computer, start the car & drive away-ish
Obviously there will be some more tuning than that depending on your engine , inlet & exhaust specs, but our initial "start up & run" program should get you on the right path
Hoping we can get some go forwards with all this & have them packaged up by early in the new year, so if you`re thinking of doing a Twinky conversion but are maybe a little worried about what to do , or lack of support, or can`t make all this stuff yourself,,, Please don`t be affraid,,, i will be continuing to make & develope stuff to suit this cyl head & most of the gear i make will be avaliable for sale once they`re done.
I have already spoken with a few guys that race these & have started talking turkey about the cost & avaliability of a larger cam & valve package & i have already started opening up the ports on one head, so keep an eye out for a sooped up version in the later half of next year.
Now----------->>>>>Potential of these cyl heads you may ask????
Ok--> RB Racing in the States has produced well over 300hp from their own turbo version fitted to only a 1200cc donk,,, there`s lots of power avaliable
Another friend of mine set one up in his mini & has allready seen over 200hp & still climbing with more development happening
More happening with these all the time
Grab one before they`re all gone :-)
PostPosted: Mon Oct 06, 2008 3:40 pm
Very Bling, but-
Gimme some dyno numbers, please.
Then I might be a believer... :wink:
Umm 132hp at the flywheel from a 970 :shock: http://au.youtube.com/watch?v=m_sd7StOLnU
or 107 at the wheels from a 1293 and it's only a 8 valve
http://au.youtube.com/watch?v=WBToBq6Oejo
or the full monty 127 at the wheels 1380 16 valvehttp://au.youtube.com/watch?v=00Y0fQFqbpY
and also 178hp at the fly 1399 311cams all steel internals 16 valve
http://au.youtube.com/watch?v=ymPuRbmlPJU
what more do you need
great work matt :D
I am the son of the STIG
HOTBRICKS
http://hotbricks.org.au/
'65 NCF MINI.....
PostPosted: Mon Oct 06, 2008 6:22 pm
want name the company but they have been putting Metric Bolts where Imperial bolts should be. This has been as the Cam and the reason many have been leaking Oil :roll:
PostPosted: Mon Oct 06, 2008 8:35 pm
I can't seem to google a translator for that ^^ Can we have that in english, not beerlish?
PostPosted: Mon Oct 06, 2008 9:32 pm
Extract from another Forum
Brumski wrote:
Well, tonight we've had a little iinsight into corporate infiltration...
It would appear that when BMW took over Rover, the guys from longbridge decided it would be fun to mess with the build designs of some of BMW's kit....
For tonight we found that the bolt used to secure the cam pulleys is actually a frickin Imperial bolt !!
Quite interesting don't you think.....
Especially as the frickin thread in the cam is a metric one to take an M10x1.0 pitch bolt !!
Going to get the correct bolts tomorrow but if the threads inside the cam are knackered then it's going to be '2 brand new cams please Simon !!'
So now we know why so much oil was escaping up the bolt threads - the frickin wrong bolt was fitted !!
PostPosted: Tue Oct 07, 2008 8:43 am
yeah,well, my kits have the correct sized & length bots for the cam pulleys, including the correct thick, stepped washer,,, however a little drop of locktite-515 on the threads will help seal the threads as the cams have oil pressure inside while running,,, so now you can picture a cam shaft actually physically running along the road with an oil pump up it`s bottom :-)
Back onto the wrong thread thing,,, it`s a bit like the first few years of A+ verto stuff landing here in Aust,,, for some silly reason quite a number of people just "Ass-umed" that the threads for the flywheel puller were corse thread UNC,,, but they weren`t were they??? no, they weren`t,,, so how many verto flywheels have stuffed threads now do you think??? :-) :-) :-) yes & i won`t mention any names but quite a number of well esstablished mini repair businesses called me for help with regards to this very situation :-) :-) :-) funny hey? :-) :-) ;-)
PostPosted: Tue Oct 07, 2008 6:32 pm
hay Matt..In now way did emply you were but a UK company, as per where the Quote/Thread was taken from :wink:
