It is currently Fri Jun 27, 2025 7:24 pm
Post new topic Reply to topic  [ 44 posts ]  Go to page Previous  1, 2, 3
PostPosted: Fri Feb 04, 2005 3:27 pm
gafmo wrote:
:lol: Gafmo's Bling Bling....Bugger this dellorto..bling factor
I'v seen the Manifold in Purson and the Dell sound dame nice...Its a little deaper than before but I'll be happy with it on Marcia... :shock: Nos ready
Bugger I wish I had been on the net since tuesday otherwise I would have come round today and had Lunch with you guys :x
I was in town at the Powerhouse and we spoke on ze fone, but lunch didn't happen. Chong got busy, and we had to go home.
Next time.. :wink:
PostPosted: Fri Feb 04, 2005 3:30 pm
Collies Pm's Sent
PostPosted: Sat Feb 05, 2005 3:47 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
hey gaf ya recon you could bling my 45 4 pack of jd in it for ya :)
oh but ya need to get that ****** paint crap off it
makka
PostPosted: Sat Feb 05, 2005 6:21 pm
Not being a smart arse Doc but Graham Russell told me alot of work had to go into this manifold to make it work, then the results are clear.
"Goes harder than my well-ported Redline one, no filter on yet. " does it go harder because of the lack of filter?
I was looking to buy one of these $300 manifolds from Graham after seeing the Nb of Greg Malure at Warwick last year. Without development they won't work is what he told me. Maybe your lucky and have the conbination right but I had to settle for a Redline $165 job. It's been ported and now polished on the outside not for the wank factor but to reduce heat intake.
PostPosted: Sat Feb 05, 2005 6:28 pm
Rupert, I got to see this manifold first hand on Doc's car last night, It definately has more grunt up high, Doc would be the one to comment on the development and specifics but as has been mentioned before there is a lip where it bolts onto the head which is good for 5hp and 5lb of tq...
Just by looking down the thing you can see it's alot straighter and bigger than the redline. I don't think the lack of filter would make too much of a difference, there is just no filter cause it isn't able to fit.
PostPosted: Sat Feb 05, 2005 6:39 pm
Rupert,
I had the Redline on it before, with 9 hrs porting work inside, it was pretty good. This one is way better, all the way up.
No it's not the lack of filter- I ran the Redline without one too for a trial, a while back.
I didn't port or match this manifold, as GR told me not to- I just bolted it on.
The head has 35.6mm/31mm valves, ports are pretty big for a roady motor. C/R is 10.4:1.
We'll see how good it is at Wakefield on Wednesday- with the old manifold, & 3.4 diff I used to hit 96mph on the straight before I chickened out for the kink & turn 1. :oops: :wink:
PostPosted: Sat Feb 05, 2005 8:01 pm
Oh great, I was talked out of the Russell manifold!!!!!
That really shits me as I've spent way more than $10,000 on the engine & box and I'd really hate to have all of these $$$$ resricted by a measly couple of hundred dollars.
Bloody Mini
PostPosted: Sat Feb 05, 2005 8:06 pm
Bloody Mini
So, which Redline is it- 3005 (road) or <edit> the longer 3047 (race)? :wink:
Mine was a 3005....
Last edited by drmini in aust on Sat Feb 05, 2005 8:48 pm, edited 2 times in total.
PostPosted: Sat Feb 05, 2005 8:33 pm
Rupert, the maifold Doc is running is not the same one that Greg Malure runs on his Nb Mini, Greg runs a longer one, hence Doc's last question. Given the state of tune of Gregs engine, I doubt his manifold is the same as any you buy. Serious work gone into the engine and set up.
I was at Warwick and saw it run, took poll position off XUI's!! Steve
PostPosted: Sun Feb 06, 2005 7:11 am
that clears up that then.
i'm using a Redline 12-3047
PostPosted: Sun Feb 06, 2005 4:40 pm
makka
Pull it appart as I have done and sand blast the bugger... mate :idea:
PostPosted: Sun Feb 06, 2005 4:50 pm
Mine was a 3005....
Doc's old 3005 is Mine Mine Mine... 8) all the hard work is done....just need to open it upo a little more for the 48 :? Ar9 hours Plus 2...I'll take the two thanks....Minie Mine Mine 8)
I had another play today with Haha..yep it is a lot better than the Doc's old (Mine) inlet Manifold..it comes in ealier and has a totaly differnt note out the back..Much deaper...I have not idea about Greg Malure inlet manifold but I like Doc's one :!:
Just one Greg He can Drive
 Post subject: Bling
PostPosted: Sun Feb 06, 2005 10:49 pm
makka
After you get the paint off, take it to a carbie place and get them to sit it in the carbie clean tub overnight. 8)
KB
PostPosted: Mon Feb 07, 2005 6:04 am
I just gave my Dellorto the Nulon `throttle body & carb cleaner' treatment- it's good stuff. :wink:
Cut the firewall hole bigger too- now I can fit a Ramflo and a box in, after the binnacle is moved into the car a bit. 8)
For this week I've put some heavy duty soundproofing over/into the hole, tied it back onto the speedo cable. Helps shut it up some....!
