It is currently Thu Jun 26, 2025 4:41 am
Post new topic Reply to topic  [ 44 posts ]  Go to page 1, 2, 3  Next
PostPosted: Wed Feb 02, 2005 3:45 pm
Well I put it in today and took it for a run. Goes harder than my well-ported Redline one, no filter on yet. But it'll do for Wakefield Pk track day next week.
Had to cut the firewall hole a little on passenger side. Gotta move the speedo binnacle into car a bit, and then make a shallow box up, then bung a filter or socks on.
Played with the jets this arvo, 45 Dellorto's now got 36mm chokes, 180 airs, & 165 mains in it, and my stubstacks. 8)
Carb angle is 12*, a lot more than stock, but the Dellorto handles it OK. My Redline one is 16*... :shock:
PostPosted: Wed Feb 02, 2005 4:08 pm
looks good
nice work DOC :D
Nigel Morton/ Team Brickworx
never late in a 998
PostPosted: Wed Feb 02, 2005 4:52 pm
schnice doc! :P
PostPosted: Wed Feb 02, 2005 5:07 pm
Look! Tassy is at the top! :lol: :lol: :lol:
PostPosted: Wed Feb 02, 2005 6:03 pm
Optical delusion... :wink:
I'll take it out again Saturday, gotta make a bit more room behind and stick some aluminized soundproofing in there. I'll be deaf by the time I get to Wakefield, otherwise... :lol:
And I thought it was LOUD before... :wink:
PostPosted: Wed Feb 02, 2005 7:07 pm
ooooo looks nice dr, another secret weapon for wakefield, looks like i will need to run full boost now :D
1974 Moke - 998cc
PostPosted: Wed Feb 02, 2005 7:15 pm
I do have another couple of `secret weapons' Brad, but they won't be ready for a while... 8)
 Post subject: Needs bling!!
PostPosted: Wed Feb 02, 2005 7:18 pm
Two things Doc.....
Aren't Webers usually flexibly mounted between manifold and carb body :?:
Where is the throttle return spring teethered too :!: looks like it is on a skyhook :!:
oh yeah....carb needs Gafmo bling treatment to go with the flash new manifold :!: :lol:
PostPosted: Wed Feb 02, 2005 7:25 pm
1. It ain't a Weber. Dellorto 45DHLA is quite happy using the standard gaskets in the repair kit for the last 10 years. Better float & needle setup than Weber, IMO.
2. Return spring is attached to a S/S wire hook tied into the firewall.Easy to unhook spring- I can get this carb & manifold out in 5 mins. (try that with a pair of HS4s..)
3. I like my carbs au naturel... 8)
The filter is Bling!, when I've made room for it.. :D
 Post subject: DCOE!!!
PostPosted: Wed Feb 02, 2005 7:39 pm
I dint even look that close....saw the DCOE title and assumed Weber DCOE...
The flexible mounts should be needed on a Deloroto as well :?: Its all about isolating engine vibration which can disrupt the operation of the sidedraft carb (isn't it :?: )
Yeah.....Go will always be more important than Bling in my book :!: :shock:
PostPosted: Wed Feb 02, 2005 7:56 pm
Folklore says the vibration can make the fuel foam in the bowl, or the carb flood. Yes it does this with Webers. I've never seen it happen with a Dellorto though. Later design... 8)
I found the flexible mounts are more trouble- they can crack with old age, or collapse, or leak fuel.. :x
A gasket is 2 or 3mm thinner- I need the room! :P
PostPosted: Wed Feb 02, 2005 8:12 pm
I was also going to say it needs some bling (or at least carbie clean) to match the manifold.
ps had my eye on a ribbed alloy rocker cover on ebay speaking of bling - last time I looked it was over $150!!
PostPosted: Wed Feb 02, 2005 9:31 pm
OK... I'll bow to your wishes and give it a quick Nulon throttle body cleaner `treatment'.
Hey I did spray some degreaser on it!
I just wanted to try it out, and jet it for Wakefield... :P :P
PostPosted: Wed Feb 02, 2005 10:34 pm
You could dirty up the manifold instead :) - then it wouldn't look out of place 8)
You'll be looking at a set of splits next.
Next comes the serious lightweighting - stop when you start drilling the taillight backing plates.
PostPosted: Wed Feb 02, 2005 10:40 pm
Hey Kev,
now you know how Deaf I am after driving around for months & months without a weber box..
Yours will go like a rocket even more now.
Smiles
Bara
Users browsing this forum: No registered users and 24 guests
