It is currently Wed Jun 25, 2025 9:05 pm
Post new topic Reply to topic  [ 47 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Sat Mar 22, 2008 11:19 pm
Forum Graffiti
Kennomini wrote:
Is that a cast iron block :shock:
Looks like it... it only weighs 2kg more than a VTEC though :wink:
PostPosted: Sat Mar 22, 2008 11:41 pm
Forum Graffiti
EDIT
PostPosted: Sun Mar 23, 2008 12:34 am
http://www.youtube.com/watch?v=gRCd79SY ... re=related
hey... it's relevant :)
PostPosted: Sun Mar 23, 2008 9:42 am
Forum Graffiti
cush wrote:
http://www.youtube.com/watch?v=gRCd79SYyPM&feature=related
Yeah seen that vid, good watch :)
PostPosted: Mon Mar 24, 2008 8:29 pm
Forum Graffiti
Ok I 've been thinking away about the ITB manifold for a while and I really like this idea ---
http://www.homemadeturbo.com/tech_projects/itb/
The only difference is I'll put a slight bend on the runners to angle them more upwards...
Opinions?
PostPosted: Tue Mar 25, 2008 8:08 pm
Interesting Sam - would like to see what it does to midrange and top-end!
PostPosted: Tue Mar 25, 2008 9:06 pm
A comparison between a honda and a nissan is relevant to a bitsamissing conversion? Even for you cush, that's a long bow to draw.
PostPosted: Tue Mar 25, 2008 10:35 pm
it's relevant to this post..
Archangel007 wrote:
4G92 MIVEC:
Type: Transverse in-line 4
Bore x Stroke: 81.0 x 77.5
Capacity: 1597cc
Valve Train: DOHC 16v with MIVEC
Compression Ratio: 11.0:1
Fuel System: (Mitsubishi) Multi-point Fuel Injection
Power: 172Hp at 7500rpm
Torque: 166Nm at 7000rpm
B16B Type R:
Displacement: 1595 cc
Compression: 10.8:1
Bore: 81mm
Stroke: 77mm
Rod/Stroke ratio: 1.84:1
Power: 185 hp (137 kW) @ 8200 rpm &
Torque: 118 ft·lbf (160 N·m) @ 7500 rpm
The MIVEC might lose out on horsepower, but it gains it in torque against the 'hot' B16.
It is 200cc smaller than the B18C, so that's an unfair comparison.
And the Nissan:
Displacement: 1.6 L (1596 cc)
Valve Timing: Nissan's Neo VVL variable valve timing with lift control.
Power: 175 PS (129 kW) @7800 rpm
Torque: 119 ft·lbf (161 Nm) @7200 rpm.
Redline is at 8300 rpm.
Once again, loses out on outright hp (just), but gains in torque. This motor is a fantastic swap for the Mini, and will make most of the forced induction lads blush!
Tricky
PostPosted: Sat Apr 26, 2008 4:30 pm
got any updates?
Mearcat wrote:
PostPosted: Sun Apr 27, 2008 5:13 pm
Forum Graffiti
dbr11k wrote:
got any updates?
Very soon! The subframe's under way :D At the moment I'm finalizing my ideas for my brakes and suspension setup... I'll post an update when I get the subby back :)
PostPosted: Sun Apr 27, 2008 6:47 pm
Big motha fakars :D thats what you should get :lol:
PostPosted: Sun Apr 27, 2008 7:19 pm
Forum Graffiti
:lol: That's the plan! I was thinking of these, but TBH I think they'll be overkill ! ---
http://www.mra-minis.co.uk/megabrakes.htm
These are what I've settled on at the moment...
http://www.minispares-online.co.uk/?cat ... od_id=1410
And for suspension ---
http://www.minispares-online.co.uk/?cat ... rod_id=578
8)
PostPosted: Sun Apr 27, 2008 8:04 pm
Those tarox brakes look awsome!!! I have a set but am yet to use them, Josh is running them on his...
Life's a garden.... Dig It!
PostPosted: Mon Apr 28, 2008 11:15 am
The TAROX Brakes are great - i'm running them without a servo and they're awesome. 'Only' 235mm though but i couldn't fit anything bigger inside the 13" rims. That 285mm kit has no hope.
I also don't like this part:
"THE WELDING AND FITTING OF THESE KITS MUST BE COMPLETED BY A COMPETENT PERSON" :shock:
PostPosted: Mon Apr 28, 2008 1:02 pm
Forum Graffiti
Hey buddy,
I had a look through your thread and they look great! I'll be running a servo as well so they should be right :)
Yeah I didn't like the fact that you needed to strengthen the subframe for the suckers.. how much force are they expecting!? :shock:
