It is currently Wed Jul 09, 2025 12:47 pm
PostPosted: Wed Nov 21, 2007 9:00 pm
how's this for an idea
how about some sort of impeller fan that is in the exhaust pipe, and the exhaust gases make it spin around really fast, that fan is connected with a shaft to another fan type thing that sucks air in and pushes it into the engine.... I reckon that could work
I guess the same sort of thing could work if you drove the second fan from the fan belt as well, but maybe not an actual fan because it mightn't spin fast enough, but maybe a pair of rotating drum things with interconnecting ribs that forces air between them and out into the engine
just an idea :roll:
PostPosted: Wed Nov 21, 2007 9:53 pm
bnicho wrote:
Vizard tried a similar idea and found there was a torque benefit in a long intake pipe with a K & N filter down behind the grille. See "Tuning BL's A Series Engine" for details. But Vizard wasn't intending to "ram in" air, just suck in cooler air.
yes, this rearly works. but what you gain at the lower revs is what you lose at the higher revs. the idea is to "ram in" the air, but it only works within a narrow rev band. to make it perfect you need long intake pipes for low revs and short pipes for high revs
Rover 214 atm ....
PostPosted: Wed Nov 21, 2007 10:06 pm
This space for rent
It'll never work :P
PostPosted: Thu Nov 22, 2007 4:47 pm
sgc wrote:
It'll never work :P
I have seen them, they are called rotary mufflers.
PostPosted: Thu Nov 22, 2007 7:39 pm
sgc wrote:
It'll never work :P
Some rotaries are noisy so they put 2 of these mufflers on. It seems to help their performance too. :lol:
PostPosted: Thu Nov 22, 2007 7:42 pm
Rotary engines will never be successful. 8)
PostPosted: Thu Nov 22, 2007 9:31 pm
sounds awully a lot like a hair dryer lol
Mearcat wrote:
PostPosted: Thu Nov 22, 2007 10:34 pm
BING!!! :idea: :idea:
maybe you're on to something there, how about pulling apart a real hair dryer and putting it into the air filter housing inlet....
dude, we're gonna make a fortune
PostPosted: Thu Nov 22, 2007 10:40 pm
hahahaha... my my
where am i again lol... oh yeh on aus mini "where else"
i was going to do some thing like a large heatsink fan inside a flex tube once and run it to my pod filter
sorta couldnt be stuffed, for the hassle there isnt much gain
Mearcat wrote:
PostPosted: Thu Nov 22, 2007 11:04 pm
Any one remember "Turbozet"?
It was an "Electronic Supercharger" that sold for about 300 dollars.
It claimed to increase horsepower by 5 percent or so and increase economy.
It was two 5 dollar plastic PC cooling fans glued together. Often one fan was fitted bacxkwards to the other as well. :lol: :lol: :lol: :lol:
So many suckers, so few turbozets...
Someone worked out that to produce the amount of air needed to make any sort of difference, the electric air pump motor would need to be about the size of a pool pump and draw about 100 amps at 12 volts!
PostPosted: Fri Nov 23, 2007 5:51 am
There's a sucker born every minute, that's probably faster than Turbozet production... :lol:
PostPosted: Fri Nov 23, 2007 8:03 am
When I was into VW's many years ago someone published a spoof advert in the April issue of the club newsletter for the "Stylus 2000 Supercharger" for $999. He put an old 240V hairdryer on top of a 1200cc beetle carby with 8-10 ignition coils connected to it, supposedly to generate enough volts to power the hairdryer. He had fake dyno sheets showing it upped the power to 240hp. It all looked very convincing and gave us all a chuckle. The contact number was apparently a local brothel. I wonder how many people saw the article and called the number. :)
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Fri Nov 23, 2007 11:45 am
What is the temperature of the air coming in the grille?
What is the air pressure of the air coming in the grille?
What is the temperature of the air at the carby?
What is the air pressure of the air at the carby?
Have you ever heard of carby ice?
What makes you think that the air coming into the carby can be improved? 8)
Happens EVERY trip I make to Sydney from Canberra in Winter!!!!
Always, without fail - and ALWAYS!!!! after I have passed the second exit to Goulburn. Just stop, have a smoke, contemplate pissing on the DHLA, refrain reminding myself of the smell, wait another 5 mins and get in and drive...could be the Goulburn gremlins giving me gypp!!
Hooroo
Rob Forsyth
Miniot!!
PostPosted: Fri Nov 23, 2007 4:48 pm
I get carby ice on the Federal Hwy at Lake George and on the Northern Road between Bringelly and Penrith. But only if the conditions are right. :wink:
PostPosted: Fri Nov 23, 2007 6:07 pm
Only time I ever got it was in the hills above Queenstown, Tasmania- in May last year.
It's a weird feeling- you back off the throttle and it keeps going... :shock:
Just what you need (NOT!) when there's a 1 in 10 downhill right ahead... :!:
