It is currently Fri Jul 04, 2025 10:45 pm
PostPosted: Mon Jul 02, 2007 6:56 am
Simon,
The engine pics and the rwd chain drive setup are from different cars.
The yellow ZX9R has front mount (north-south) mounted engine with what I believe to be RWD by standard conventional IRS system and propshaft.
The white car in the last pic is rear mount (east-west), RWD via chain as is the standard with Z-cars and the like.
Tricky
PostPosted: Mon Jul 02, 2007 7:34 am
So is the RWD car a locked diff (or no diff)?
In fact the same question still applies for the FWD car....
PostPosted: Mon Jul 02, 2007 7:51 am
Yes, the chain driven RWD car (white one) is essentially locked. That is either an early Z cars kit or a holeshoot racing kit (or a home job).
The other front mounted car (yellow) is the one that would use some donor diff. This would be my preferred option, bit heavier though. Don't know if anybody has looked at bike motors in great detail but the 'output' shaft (where the cog is) is quite high on the motor/gbox set up. I would suggest that in the yellow car the output shaft to tail shaft 'link' would be ABOVE the steering rack. If not, great.
PostPosted: Mon Jul 02, 2007 8:45 am
Archangel007 wrote:
Simon,
Tricky
ah... that's what lack of sleep and general insanity will do to you...
PostPosted: Mon Jul 02, 2007 12:33 pm
You guys should check this out.
http://www.pistonheads.com/gassing/topi ... 0&t=403775
Another one
PostPosted: Mon Jul 02, 2007 9:27 pm
Ah yes,
ZX12R engine, solid small diameter prop shaft, and Ford Sierra rear end - a popular combination in the UK.
JC - the propshaft will clear the rack no worries.
Simon - sorry!! Please get some sleep.
Tricky
PostPosted: Tue Jul 03, 2007 10:09 pm
Sorry if I have opened a can of worms HEHE
PostPosted: Wed Jul 04, 2007 8:18 am
No no gafmo, open as many as you like. It's good to get it all out.
PostPosted: Wed Jul 04, 2007 11:12 am
Ad this one too, Hayabusa V8 :D
http://thekneeslider.com/archives/2005/ ... v8-engine/
Roundies Rule !!!
PostPosted: Wed Jul 04, 2007 12:36 pm
That's a US$40k motor.
PostPosted: Wed Jul 04, 2007 1:29 pm
Didnt see that, lol.
Roundies Rule !!!
PostPosted: Wed Jul 04, 2007 7:36 pm
And no chance of going in a road-registered Mini!!
PostPosted: Thu Jul 05, 2007 6:38 am
lol....I was at that- Gaydon Mini Festival, and took about 10mins DVD of this...awesome wee car.........the pics dont do it justice, everywhere you looked it was tweaked or modded and the workmanship was awesome.....
As seen from the pics tho, it p**ed it down-ruined the day, but were some very cool minis there - Heritage Motor Centre was well worth the look too!
Glenno
If you idiot proof the world, only idiots there shall be!!!!!
PostPosted: Fri Jul 06, 2007 11:26 am
I posed the question to my engineer about the feasability of going RWD with a mini like the above yellow one in th UK, this was his response....
The NSW regulations mean that if you convert to RWD we need to asses the car as an individually constructed vehicle against all of the 2007 regulations.
If money really wasn't an object this could be done. In the real world I suggest you stick to FWD!
Roundies Rule !!!
PostPosted: Thu Dec 06, 2007 11:37 pm
check out the wiper arms on it
Mearcat wrote:
