It is currently Sat Jun 28, 2025 2:47 am
Post new topic Reply to topic  [ 53 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Mon Apr 23, 2007 7:28 pm
The wheels were one of the first things i bought for my van, would have been atleast 2 years ago... Atleast they still look good
I couldnt stand to look for another set and sell the superlites... Maby when i win loto
Life's a garden.... Dig It!
PostPosted: Tue May 15, 2007 6:17 pm
Ive finally got all the wheels on and suspension together for a trial fit, all clearances with the 13x7's and coilvers look alright
Im abit worried about my ground to subframe clearance at the moment its at its highest setting and have 130mm could any1 confirm the minimum distance allowed????
Also have been cutting up my intake mainfold and rewelding it with a bit more of a curve in it to clear the fire wall.
:P :P
Vtec Mini clubman. Commenced Jan 06.
Still Going June 07
http://s25.photobucket.com/albums/c71/sunburstvl/
PostPosted: Tue May 15, 2007 7:14 pm
Very nice, keep up the good work.
Cheers Paul
PostPosted: Tue May 15, 2007 7:15 pm
Those wheels still look kick ass
PostPosted: Tue May 15, 2007 7:40 pm
100mm from lowest point to the ground is the legal requirement for clearance.
(In most Australian states/territories)
PostPosted: Tue May 15, 2007 9:03 pm
that's the ADR design rule.... 100mm. Before Minis were released here, it was 150mm minimum, they changed the rules for us... ain't that sweet
I was thinking it was gonna be driving! but I'm not disappointed, looks great - I still love that colour :D
PostPosted: Tue May 15, 2007 9:33 pm
Cheers, thanks for that , i can go lower it an extra 20mm now lol :P :P
Still Going June 07
Still Going June 07
PostPosted: Thu May 17, 2007 10:33 pm
I'm keen to see progress shots of your intake modification - I need to do the same with mine. Granted my engine is a D series, but the process is the same.....
thought about making a new one?
PostPosted: Sat May 19, 2007 12:30 am
I'll hopefully finish it this weekend and will post more pics then, as for making one i thought it be easier just to mod the stock one.
Ive still had to cut some of the firewall though but not much will get some pics soon
Steve :P :P
Still Going June 07
PostPosted: Mon May 28, 2007 4:41 pm
Here's some pics of my brackets i made up for my alternator which just fits under the bonnet :D.
Also the honda brakes im making.
:wink: :wink:
Still Going June 07
 Post subject: lookin good!
PostPosted: Tue May 29, 2007 1:41 pm
Sunburst
Looking good mate.
What Honda are the discs off? Size? And how to they attach to the drive flange? Are you using the normal disc drive flange?
Madmorrie
PostPosted: Tue May 29, 2007 4:05 pm
Thanks madmorrie,
The disks are from a ED CRX 1.6 litre 2-Door DX-Si Non vtec, and i think the calipers are the same but not 100% because they are were secondhand and could of came off something else, but that was what i ask for when i bought them.
Part # was DBA187 242mm Dia 44.5mm Wide 19mm thick.
As for attaching it to the flange i've got the studs going through the disc and into the 8.4 disc flange.
I just need to figure out where to put holes for the 2 screws, or does any1 know if you even have to have them??? because it will be secure enough with just the studs.
Steve :wink: :wink:
Still Going June 07
PostPosted: Tue May 29, 2007 10:23 pm
watch out with those rotors, they're not designed to have studs going through them to secure them to the drive flange, it's only thin cast iron and can crack very easily.....
I thought of doing similar to you, but putting a 1/2" plate behind the rotor to mount the studs, and bolting the flange through the rotor into the plate as well
PostPosted: Wed May 30, 2007 8:25 am
Good thinking i might make up a plate, and then ive got something to mount to.
Thanks
Steve
Still Going June 07
Users browsing this forum: No registered users and 31 guests
