It is currently Thu Jun 26, 2025 4:20 am
 Post subject: Frame is Finished Yay!
PostPosted: Sun Dec 05, 2004 8:28 pm
Alright people frame is complete.
Any comments welcome. Also welded the back spar with the frame bolted in and guess what she fits this time (how surprising, said idiot boy!). And yes the lower control arms are in aswell. :D
PS. Not final colour, colour of primer.
PostPosted: Sun Dec 05, 2004 8:43 pm
thats a hell of a lot of work
lets just hope she fits :wink:
Inconspicuously Conspicuous
PostPosted: Sun Dec 05, 2004 8:44 pm
Nice work dude 8)
Lol...just saw the PS..was gonan say that yellow wouldnt be my choice of colour!
[Maverick] 1971 Mini K
PostPosted: Sun Dec 05, 2004 8:46 pm
btw is that the foamy stuff youre going to put in your car?
i hope not
gets very wet
PostPosted: Sun Dec 05, 2004 8:53 pm
great job :D only one thing, where are the engine mounts? :shock:
Whats your aim of attack with the lower mount?
1974 Moke - 998cc
 Post subject: Yay is right!!
Well done Matt, very well done!.
Hint: now is the time to measure everything and ensure you have all the drawings of what you have built for future reference.
Terrific to see....Cheers, Mick
Hint #43 have you completely de-burred, removed sharp edges from the entire frame?? (now is the time so you don't have to curse yourself when tear flesh later!! :wink:
 Post subject: In order
PostPosted: Sun Dec 05, 2004 9:11 pm
Well 68matic I welded the back brace with the subframe bolted in and surprise when I took her out and then put her back in she fits perfect (I even advise other to do this and didn't follow my own advice :lol: ). As for the foam no this is just to stop the paint being scrapped off on the floor of the garage. As for the mounts Brad, yeah they're coming. Decided that I should get the car on all fours before I dropped the engine in and then start marking up. I have a pretty good idea on what to do with the mounts but this won't happen till new year. Don't worry I will probably send you questions when the time comes :wink: . Yeah the yellow if funky but I aint. I was actually going gloss red what do people think? And finally Mick, cheers mate, and yes got a coarse wire wheel and angle grinder on to every weld so she is pretty schmick now. Some of the welds weren't that pretty but good penetration for sure :)
PostPosted: Sun Dec 05, 2004 10:52 pm
Nice bit of work there mate, you should be proud :)
PostPosted: Mon Dec 06, 2004 6:53 am
Nice job and I'v been watching from afare with the amount of work you have done.
Not sure about the colour also but hay Mine are green...better than the standard black...Go the Red 8)
 Post subject: Colour
PostPosted: Mon Dec 06, 2004 8:34 am
Yeah MiniK said the same thing, but as he realised the colour won't be the final. Yeah Fluoro Yellow probably ain't the best. I will eventually paint the car Sunburst Orange with two fat black racing stripes from head to toe so the read subframe will probably work in well. Cheers for the encouragement everyone...
PostPosted: Mon Dec 06, 2004 8:47 am
Well done!!
Spray it hammertone!!!!! I did my fuel tank in it...looks tops!
 Post subject: Not a bad idea
PostPosted: Mon Dec 06, 2004 10:01 am
Hey Anton, not a bad idea! Also can you clear something up I am still trying to source a spray gun. I was going the HVLP but talked to a guy at an automotive paint shop and he said give the large point ie 2mm for acrylics that this defeated the purpose of having a HVLP gun? Also can you get Hammertone in tins ie for spraying...
 Post subject: Re: Not a bad idea
PostPosted: Mon Dec 06, 2004 10:11 am
minstar wrote:
....a guy at an automotive paint shop and he said give the large point ie 2mm for acrylics that this defeated the purpose of having a HVLP gun...
pffffffttt....why would they make them then? I asked a zillion people about everything before buying and spraying. No one told me that.
Most panel shops use HVLP gravity guns. Yea, they are mainly spraying 2 pack, but not all the time.
I have used HVLP gravity guns AND standard siphon pot guns. HVLP are better IMHO.
re: hammertone in a can to mix and spray......YES. Kill Rust brand at your local hardware. You WILL need to thin it though. See what it says on the label. Probably TURPS.
PostPosted: Mon Dec 06, 2004 10:24 am
I have used a HVLP for spraying both acrylics and 2 packs (and a normal gun for spraying acrylics and 2 packs). I have found that you can get a better finish with a HVLP without being any good at spray painting. Plus you get alot less overspray, which is what they are supposed to do.
Normally when i'm spraying something that i dont really care about the finish too much I just use a normal gun. Mainly as its easier and quicker to clean up afterwards.
PostPosted: Mon Dec 06, 2004 10:29 am
Investing in a $15 stand for any gravity feed gun is a must. I tried hanging mine on the garage door opener....it fell off and the pot cracked....PLUS paint went everywhere!!! :evil:
Users browsing this forum: No registered users and 21 guests
