It is currently Thu Jun 26, 2025 12:06 am
Post new topic Reply to topic  [ 118 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 8  Next
PostPosted: Fri Mar 02, 2007 7:31 pm
Yeah, like this guy
http://www.youtube.com/watch?v=61omPpPBxF8
PostPosted: Fri Mar 02, 2007 7:39 pm
Sure is buddy. lol
If it cant be fixed with a hammer it cant be FIXED!!
PostPosted: Fri Mar 02, 2007 7:41 pm
Sure is great work job well done...just waiting to get mine finished also...one day
love the look and easger to see how they work under pressure :wink:
PostPosted: Fri Mar 02, 2007 7:58 pm
Well hopefully i will know within the next fortnight or so. Thats if it ever stops raining up here.....
PostPosted: Fri Mar 02, 2007 8:00 pm
I'm sure it'll stop better than any Mini has a right to. I did the ones on Josh's Clubby, now on da Moke. :wink:
PostPosted: Fri Mar 02, 2007 8:02 pm
Thats a good way to put it!!!!!!!
Thanks for your advice with all ok this Kev! Greatly appreciated.
PostPosted: Fri Mar 02, 2007 8:22 pm
I can get the back wheels on the moke off the ground :D skipping anyway..must do a vid to see how much :lol:
PostPosted: Thu Mar 15, 2007 6:47 pm
So im still waiting on my bits to be powdercoated. But just another update on prices...
Brake conversion so far:
2 new RDA Rotors: $88
2 2nd hand calipers: $110
Machine work: $451
2 Caliper Kits: $38
4 RDA brake pads: $44
Price so far...............$731.......
Still to come, the bill from the powdercoaters... And that should b about it...
PostPosted: Tue Mar 27, 2007 10:50 pm
Ok so i finally got my bits back from the powdercoaters.... Really good job, as always. $200 later which is pretty good considering they did it on a Sunday for me.......
I did have to remove some powdercoating from the mounting points to ensure everything fitted together how it was originally planned. No big deal for my dremel tool
Now i just have to get the calipers back together with the new seals installed......Tricky!!!
So Brake Conversion so far:
Machine work: $451
2 Caliper Kits: $38
Powdercoating: $200
Total: $931
PostPosted: Tue Mar 27, 2007 10:51 pm
Coming along well
PostPosted: Tue Mar 27, 2007 11:21 pm
that would be a goood conversion, bit steep though, but will pull you up well.
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Wed Mar 28, 2007 7:25 am
mad-mk1 wrote:
bit steep though.
Well if i had access to cheap 2nd brake parts that may of brought the cost down a bit, (most people seem to get there calipers and rotors for $100.....) plus i could quite easily of used the calipers as they were. The seals were all good, and the pads had plenty of meat on em. It was just the machine work that turned out to be very expensive.
So really if i wanted to do it on the cheap, it could of cost me half of my total cost.... But this is something that i must do right the first time, so while they are apart, thats the best time to replace bits.
PostPosted: Wed Mar 28, 2007 10:37 am
Hanra wrote:
Jeez mate, clean the underside of your car already... it's filthy... :wink: :shock:
PostPosted: Wed Mar 28, 2007 12:33 pm
I know....... Ive been slack!
PostPosted: Wed Mar 28, 2007 12:41 pm
Hanra wrote:
But this is something that i must do right the first time.
Unlike BMC... who made the 7 inch discs first up...
but then they fixed it by making the 7.5s.... and all was good...
